Updated on 2025-07-07 GMT+08:00
Overview
Different from conventional passive caching solutions, memory acceleration of GeminiDB Redis API speeds up access to TaurusDB databases. Users can create rules on the GUI to automatically cache TaurusDB database data.
The conventional caching solution is inefficient and unreliable because users have to develop code for caching TaurusDB instance data. GeminiDB provides an automated proactive caching solution to prevent transaction failures caused by cache breakdown. After parameters are configured on the GUI, data can be automatically synchronized. You can also filter data and set a validity period to enhance development efficiency and data reliability.
Figure 1 Memory acceleration
