Help Center/
TaurusDB/
User Guide/
Database Usage/
Database Management/
Modifying the Description of a Database
Updated on 2025-08-21 GMT+08:00
TaurusDB allows you to modify the description of a created database.
- Click
in the upper left corner and select a region and project. - Click
in the upper left corner of the page and choose Databases > TaurusDB. - On the Instances page, click the instance name.
- In the navigation pane, choose Databases.
- Locate the target database and click
in the Description column to modify the description.
The database description can be empty or contain up to 512 characters.
- To submit the modification, click
. - To cancel the modification, click
