Resetting the Administrator Password
If you forget the password of your database account when using TaurusDB, you can reset the password.
If an error occurs on the root account, for example, if your root account credentials are lost or deleted, you can restore the root account permissions through resetting the password.
Precautions
- If you have changed the administrator password of a DB instance, the passwords of the read replicas associated with the instance will also be changed accordingly.
- The time it takes for the new password to take effect depends on the amount of service data currently being processed by the primary node.
- To protect against brute force hacking and improve system security, change your password periodically, such as every three or six months.
- The instance may have been restored from a backup before you reset the administrator password.
- If you have logged in to your instance as the root user, resetting the password may interrupt services. Exercise caution when performing this operation.
The password cannot be reset in any of the following situations:
- Your account is frozen.
- The database port is being changed.
- The instance status is Creating, Restoring, Rebooting, Changing port, Changing instance specifications, Promoting to primary, or Abnormal.
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region and project. - On the Instances page, locate the instance for which you want to change the password and choose in the Operation column.
Alternatively, reset the password using either of the following methods:
- On the Instances page, click the instance name to go to the Basic Information page. In the upper right corner of the page, click Reset Password.
- On the Instances page, click the instance name to go to the Basic Information page. Expand Instance Information. In the Configuration area, click Reset Password under Administrator.
- If you have enabled operation protection, click Start Verification in the displayed dialog box. On the displayed page, click Send Code, enter the obtained verification code, and click Verify to close the page.
For details about how to enable operation protection, see Identity and Access Management User Guide.
- In the displayed dialog box, enter and confirm the new password.
The new password must:
- Consist of 8 to 32 characters.
- Contain at least three types of the following characters: uppercase letters, lowercase letters, digits, and special characters (~!@#%^*-_=+?,()&$|.).
- Comply with the values of validate_password parameters. To check the password-related parameters, click the instance name, choose Parameters in the navigation pane, and search for validate_password in the upper right corner of the page.Figure 1 Checking the password-related parameters
- Click OK.
Keep this password secure. The system cannot retrieve it.
