Updated on 2026-02-02 GMT+08:00
Deleting a DB Instance
You can delete a pay-per-use or serverless DB instance on the Instances page to release resources. The instance status will change to Deleting. You can check the task progress on the Task Center page. When the progress reaches 100%, the DB instance has been deleted.
To delete a yearly/monthly DB instance, you need to unsubscribe from the order first. For details, see Unsubscribing from a Yearly/Monthly DB Instance.
Before deleting a DB instance, check whether there are any manual backups. If you do not need to retain manual backups, delete them by referring to Deleting a Single Manual Backup before deleting the DB instance. If you have purchased an EIP, release or unsubscribe from it before deleting the DB instance to save costs.
  • Instances cannot be deleted when operations are being performed on them.
  • If you delete a DB instance, its automated backups are also deleted and you are no longer billed for them. Manual backups are still retained and will incur additional costs. If the DB instance has an EIP bound, you need to release the EIP, or the EIP will continue to be billed.
  • If you delete a DB instance, its read replicas are also deleted.
  • If a backup of a DB instance is being used to restore data, the DB instance cannot be deleted.
  • Deleted DB instances cannot be recovered and their resources will be released immediately. To retain data, back up the data first and then delete the DB instances.
  • Deleted DB instances will be moved to the recycle bin, but will be permanently deleted after a length of time determined by the recycling policy.
  1. Log in to the TaurusDB console.
  2. Click in the upper left corner and select a region and project.
  3. On the Instances page, locate the instance you want to delete and click More > Delete in the Operation column.
    Alternatively, click the instance name to go to the Basic Information page. In the upper right corner of the page, click and choose Delete.
    Figure 1 Deleting a DB instance on the Basic Information page
  4. In the displayed dialog box, enter DELETE as prompted and click OK.
  5. If you have enabled operation protection, click Send Code in the displayed Identity Verification dialog box and enter the obtained verification code. Then, click OK.
    Two-factor authentication improves the security of your account. For details about how to enable operation protection, see Identity and Access Management User Guide.
  6. Refresh the Instances page later to check that the deletion is successful.
