Updated on 2026-07-16 GMT+08:00
Exporting DB Instance Information
You can export DB instance information for further analysis.
  1. Log in to the TaurusDB console.
  2. Click in the upper left corner and select a region.
  3. On the Instances page, click Export Instance Info above the instance list. In the displayed dialog box, select the items to be exported and click OK.
  4. Check the .csv file locally after the export task is complete.
