Changing a DB Instance or Node Name
You can change the name of a TaurusDB instance or its node for easy identification.
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region. - On the Instances page, locate an instance and click
in the Name/ID column to edit the instance name. Alternatively, click the instance name to go to the Basic Information page. Locate DB Instance Name in the Instance Information area, and click
to edit the instance name.Figure 1 Changing a DB instance name
- The instance name must start with a letter and consist of 4 to 64 characters. Only letters (case-sensitive), digits, hyphens (-), and underscores (_) are allowed.
- When changing the instance name, you can determine whether to select Change node names synchronously as required. If this option is selected, the names of the corresponding nodes are changed when the instance name is changed. If this option is not selected, only the instance name is changed, and the corresponding node names remain unchanged.
- If you want to submit the change, click OK. If you want to cancel the change, click Cancel.
- Check that the instance name has been changed. It takes less than 1 minute to change a DB instance name.
- Click
in the upper left corner and select a region. - On the Instances page, click the instance name to go to the Basic Information page.
- In the Node List area, select one or more nodes, click Change Node Name. Figure 2 Changing node names
next to a node name to edit the node name.- The node name must start with a letter and consist of 4 to 128 characters. Only letters (case-sensitive), digits, hyphens (-), and underscores (_) are allowed.
- The node name must be unique.
- Click OK.
- Check that the node name has been changed.
