Help Center/ TaurusDB/ User Guide/ Data Migration/ Data Migration Schemes
Updated on 2026-04-22 GMT+08:00
You can migrate data from RDS for MySQL, self-managed MySQL, and other cloud-based MySQL to TaurusDB, or from one TaurusDB instance to another.
Migration Tools
Table 1 Migration tools
Tool
Billing
Reference
DRS (recommended)
Data Replication Service (DRS) provides real-time data migration and synchronization between databases in various scenarios. It is easy to use and can complete a migration task in minutes. DRS facilitates data transfer between databases, helping you reduce DBA labor costs and hardware costs.
Pay-per-use
For details, see Billing.
What Is DRS?
mysqldump
mysqldump is a command-line tool that comes with MySQL. It is used to back up and restore MySQL databases.
Free
What Is mysqldump?
DAS
During data backup or migration, Data Admin Service (DAS) can help you export data to a local PC or OBS bucket, and import the data to the target data table.
Free
What Is DAS?
Migration Schemes
Table 2 Migration schemes
Source Database
Migration Tool
Characteristic
Operation Guide
RDS for MySQL
DRS
  • Migration of all data, database-level data, or table-level data
  • Full and incremental data migration
  • Minimal downtime
  • Applicable to any data volume
From MySQL to TaurusDB
mysqldump
  • Full data migration
  • Long downtime
  • Applicable to small amounts of data
Migrating Data to TaurusDB Using mysqldump
DAS
  • Long downtime
  • Applicable to moderate amounts of data
Migrating Data to TaurusDB Using the Export and Import Functions of DAS
  • On-premises MySQL databases
  • ECS-hosted MySQL databases
DRS
  • Minimal downtime
From ECS-hosted MySQL to TaurusDB
Other cloud MySQL databases
DRS
  • Minimal downtime
From Other Cloud MySQL to TaurusDB
