Help Center/ TaurusDB/ User Guide/ Log Management/ Managing Slow Query Logs
Updated on 2026-10-19 GMT+08:00
Slow query logs record statements that take longer than the time specified by long_query_time (10s by default). The lock wait time is not calculated into the query time. You can check log details and statistics to identify statements that are executing slowly and then optimize the statements.
You can set log_queries_not_using_indexes to determine whether to record queries without indexes. The default value is OFF, indicating that queries without indexes are not recorded. If this parameter is set to ON, all queries without indexes are recorded and this setting is not affected by the long_query_time value.
If you need to record the number of statements without indexes per minute, you can set log_throttle_queries_not_using_indexes. The default value is 0.
  • You can view slow query log entries of a specified statement or a specific time period.
  • Only SELECT statements return the number of result rows. The number of result rows for the INSERT, UPDATE, DELETE, and CREATE statements is 0 by default.
  • You can view slow query logs of a specified database name (which cannot contain any special characters). The database name supports only exact search.
  • Slow query logs record only statements that have been executed and whose execution time exceeds the threshold. Statements still in progress are not logged.
  • The long_query_time parameter controls the execution time threshold for logging slow SQL statements. Changes to this parameter apply only to subsequent log entries. For example, if the threshold is set to 1s, slow query log entries for queries taking longer than 1s are reported. If the threshold is later reduced to 0.1s, previously reported log entries will still be displayed.
  • If the length of a single line of a SQL statement exceeds 16 KB, the statement will be truncated. When you view slow query log details, the SQL statement may be incomplete after special processing and is for reference only.
Reporting Slow Query Logs to LTS
After log groups and log streams are configured, slow query logs are stored in LTS. You can view the reported slow query logs in LTS.
  1. Log in to the TaurusDB console.
  2. Click in the upper left corner and select a region.
  3. On the Instances page, click the instance name.
  4. In the navigation pane, choose Logs.
  5. On the Slow Query Logs tab, click next to Report Slow Logs to LTS.
  6. In the displayed dialog box, specify Log Group and Log Stream and click OK.
    Figure 1 Reporting slow query logs to LTS
Viewing, Analyzing, and Downloading Slow Query Logs
You can view and analyze slow query logs on the console. By default, SQL statements are anonymized. If Show Original Log is enabled, SQL statements in the logs will be displayed in plaintext. Logs displayed in plaintext will be automatically deleted 30 days later. If a DB instance is deleted, its related logs will also be deleted.
  5. On the Slow Query Logs tab, view the slow query log details.
    • Enabling Show Original Log
      To show slow query logs in plaintext, click next to Show Original Log. In the displayed dialog box, click OK.
    • Viewing slow query logs
      View slow query logs of different nodes and SQL statements in a given database.
      Supported SQL statements include SELECT, INSERT, UPDATE, DELETE, CREATE, ALTER, and DROP.
      Click and specify a time period.
    Figure 2 Viewing log details
  4. In the navigation pane, choose Logs. On the Slow Query Logs tab, click Statistics to view details.
    Figure 3 Viewing statistics
    • On the Statistics page, only one of the SQL statements of the same type is displayed as an example. For example, if two select sleep(N) statements, select sleep(1) and select sleep(2), are executed in sequence, only select sleep(N) will be displayed.
    • However, if Show Original Log is enabled, all of the slow SQL statements are displayed. For example, if select sleep(1) and select sleep(2) are executed in sequence, both of them will be displayed.
    • No. and Ratio of SQL Executions indicates the ratio of the slow executions to the total executions of the SQL statement.
    • On the Statistics page, only the latest 5,000 slow SQL statements within a specified period are analyzed.
    • You can filter slow log statistics by database name (which cannot contain any special characters), statement, or time period. The database name supports only exact search.
    • If any database name in the slow log statistics contains special characters such as < > ', the special characters will be escaped.
    • To export statistics, click Export Current Page Data. A CSV file will be generated on your local PC. A maximum of 100 records can be exported at a time.
  5. On the Slow Query Logs tab, click Download. Locate a log whose status is Preparation completed and click Download in the Operation column.
    Figure 4 Downloading a slow query log
    • The system automatically loads the download preparation tasks. The loading duration is determined by the log file size and network environment.
      • When the log is being prepared for download, the log status is Preparing.
      • When the log is ready for download, the log status is Preparation completed.
      • If the preparation for download fails, the log status is Abnormal.
      Logs in the Preparing or Abnormal state cannot be downloaded.
    • Only logs no more than 40 MB can be downloaded directly from this page. The time range is calculated from the time you download the logs back to the time when the accumulated file size reaches 40 MB.
    • The download link is valid for 5 minutes. If the link expires, a message prompts you to download the log again. Click OK to download the log again, or Cancel to cancel the operation.
    • You can select the logs to be downloaded by node.
