TaurusDB Operations That Can Be Audited
Cloud Trace Service (CTS) records operations related to TaurusDB instances for further querying, auditing, and traceability.
| Operation | Resource Type | Trace Name |
| Creating a DB instance | instance | createInstance |
| Creating a read replica | instance | addNodes |
| Deleting a read replica | instance | deleteNode |
| Rebooting a DB instance | instance | restartInstance |
| Changing a database port | instance | changeInstancePort |
| Changing a security group | instance | modifySecurityGroup |
| Promoting a read replica to the primary node | instance | instanceSwitchOver |
| Binding or unbinding an EIP | instance | setOrResetPublicIP |
| Deleting a DB instance | instance | deleteInstance |
| Renaming a DB instance | instance | renameInstance |
| Changing a failover priority | instance | modifyPriority |
| Creating a database | instance | createDatabase |
| Creating a database account | instance | createDatabaseUser |
| Resetting a password | instance | resetPassword |
| Deleting a database | instance | dropDatabase |
| Deleting a database account | instance | dropDatabaseUser |
| Changing the password of a database user | instance | modifyDatabaseUserPwd |
| Restoring data to a new DB instance | instance | restoreInstance |
| Enabling read/write splitting | instance | openProxy |
| Disabling read/write splitting | instance | closeProxy |
| Assigning read weights | instance | setProxyWeight |
| Changing the CPU and memory specifications of an instance | instance | resizeFlavorOrVolume |
| Configuring monitoring by seconds | instance | openSecondExtend |
| Upgrading a minor version | instance | upgradeVersion |
| Adding a tag | instance | addInstanceTags |
| Authorizing database user permissions | instance | grantDatabaseUser |
| Revoking database user permissions | instance | revokeDatabaseUser |
| Applying for a private domain name | instance | createDnsName |
| Modifying a private domain name | instance | modifyDnsName |
| Changing the routing policy of a proxy instance | instance | modifyProxyRouteMode |
| Changing the port of a proxy instance | instance | modifyProxyPort |
| Applying for a private domain name for a database proxy instance | instance | proxyCreateDns |
| Changing a private domain name for a database proxy instance | instance | modifyProxyDnsName |
| Deleting a private domain name for a database proxy instance | instance | deleteProxyDnsName |
| Deleting database proxy nodes | instance | reduceProxy |
| Creating a backup | backup | createManualSnapshot |
| Configuring an automated backup policy | backup | setBackupPolicy |
| Deleting a backup | backup | deleteManualSnapshot |
| Creating a parameter template | parameterGroup | createParameterGroup |
| Modifying parameters in a parameter template | parameterGroup | updateParameterGroup |
| Deleting a parameter template | parameterGroup | deleteParameterGroup |
| Replicating a parameter template | parameterGroup | copyParameterGroup |
| Resetting a parameter template | parameterGroup | resetParameterGroup |
| Comparing parameter templates | parameterGroup | compareParameterGroup |
| Applying a parameter template | parameterGroup | applyParameterGroup |
| Querying the kernel version | instance | queryDataBaseVersion |
| Querying an auto scaling policy | instance | queryAutoScalingPolicy |
| Querying instance details | instance | queryTaurusInstanceInfoUnifyStatus |
| Querying historical records of auto scaling | instance | queryAutoScalingHistory |
| Querying an EIP | instance | queryTaurusEip |
| Querying the storage autoscaling policy | instance | queryAutoExpandPolicy |
| Querying database and table information of an instance | instance | queryTableMetaInfo |
| Querying a serverless compute policy | instance | showServerlessComputeAbilityPolicy |
| Querying custom scale-up policies of a serverless instance | instance | showServerlessScalingPolicy |
| Querying the dynamic serverless compute policy | instance | showDynamicServerlessPolicy |
| Querying an automated backup policy | instance | queryBackupPolicy |
| Querying the restoration time range | instance | getRecoverableTime |
| Querying whether backup encryption is enabled for an instance | instance | queryBackupEncryptionStatus |
| Querying the incremental backups of a specified instance | instance | queryIncrementalBackupList |
| Querying available tables for table-level PITR | instance | queryPitrDatabaseTable |
| Querying the full backups of a specified instance | instance | getBackupInfoWithPage |
| Querying proxy instances | instance | queryProxyList |
| Querying proxy instance specifications. | instance | queryProxyFlavors |
| Querying access control settings of a proxy instance | instance | getProxyIpGroup |
| Querying the minor version of a proxy instance | instance | queryProxyVersion |
| Querying kernel parameters of a proxy instance | instance | queryProxyConfigurations |
| Querying slow query log details | instance | querySlowLogFromLts |
| Querying error log details | instance | queryErrorLogFromLts |
| Querying the temporary link for downloading full SQL | instance | getAuditLogDownloadLink |
| Querying the status of Show Original Log | instance | querySlowlogSensitiveStatus |
| Querying slow query log statistics | instance | querySlowLogStatistics |
| Querying audit logs | instance | queryAuditLogList |
| Querying an audit log policy | instance | queryAuditLogPolicy |
| Querying database users | instance | queryDatabaseUser |
| Querying available character sets | instance | listDatabaseCharacter |
| Querying databases | instance | listDatabase |
| Querying the status of SQL throttling | instance | queryInstanceSqlFilterControl |
| Querying SQL throttling rules | instance | querySqlFilterRule |
| Querying user session threads on a node | instance | queryClientProcesses |
| Querying historical SQL throttling rules | instance | queryHistoricalSqlFilterRule |
| Querying auto throttling rules | instance | queryAutoSqlLimiting |
| Querying auto throttling records | instance | queryAutoSqlLimitingLog |
| Querying lock wait session information | instance | queryLockWaitSession |
| Querying historical records of intelligent session kill | instance | queryIntelligentKillSessionHistory |
| Previewing the result of intelligent session kill | instance | queryIntelligentKillSessionStatistic |
| Querying the instance list | all | queryTaurusInstanceListsUnifyStatus |
| Querying instance details in batches | all | batchQueryTaurusInstanceInfoUnifyStatus |
| Querying instances in the recycle bin | all | queryRecycleInstancesV3 |
| Querying full backups | all | listBackups |
