Changing a Database Port
You can change the database port of your TaurusDB instance. The change will be applied to the ports of both the primary node and read replicas, and all nodes in the DB instance will be rebooted. This process takes about 1 to 5 minutes.
- The database port of a DB instance with database proxy enabled cannot be changed.
- If there is an HTAP instance, the database port of the DB instance cannot be changed.
- Log in to the TaurusDB console.
- Click
in the upper left corner and select a region and project. - On the Instances page, click the instance name to go to the Basic Information page.
- In the Network Information area, click
under Database Port. The database port of a TaurusDB instance ranges from 1025 to 65534, excluding 5342, 5343, 5344, 5345, 12017, 20000, 20201, 20202, 33060, 33062, and 33071, which are reserved for system use.
- In the displayed dialog box, enter a new database port and click OK.
- If you have enabled operation protection, click Send Code in the displayed Identity Verification dialog box and enter the obtained verification code. Then, click OK.
Two-factor authentication improves the security of your account. For details about how to enable operation protection, see Identity and Access Management User Guide.
