Updated on 2026-06-04 GMT+08:00
Applying for and Changing a Private Domain Name
You can use a private domain name to connect to a TaurusDB instance.
After a TaurusDB instance is created, you can apply for and change the private domain name as needed.
  • Domain Name Service (DNS) must be deployed.
  • Changing the private domain name will interrupt your database connection. To reconnect to the DB instance, change the connection address of your applications. The new private domain name is applied to the instance about 5 minutes after the change.
  1. Log in to the TaurusDB console.
  2. Click in the upper left corner and select a region and project.
  3. On the Instances page, click the instance name to go to the Basic Information page.
  4. In the Network Information area, click Apply under Private Domain Name.
  5. View the generated private domain name under Private Domain Name.
  4. In the Network Information area, click Modify under Private Domain Name.
    Figure 1 Modifying a private domain name
  5. In the displayed dialog box, enter a new domain name and click OK.
    • Only the prefix of a private domain name can be modified.
    • The prefix of a private domain name can contain 8 to 63 characters, and can include only lowercase letters and digits.
    • The new private domain name must be different from existing ones.
  6. If you have enabled operation protection, click Send Code in the displayed Identity Verification dialog box and enter the obtained verification code. Then, click OK.
    Two-factor authentication improves the security of your account. For details about how to enable operation protection, see Identity and Access Management User Guide.
