Updated on 2026-02-02 GMT+08:00
Connecting to a DB Instance Through JDBC
If you are connecting to an instance through JDBC, an SSL certificate is optional, but using an SSL certificate can improve the security of your data. By default, SSL is enabled for new TaurusDB instances. SSL encrypts connections to instances but prolongs connection response time and increases CPU usage. Before enabling SSL, evaluate the impact on service performance. For details about how to enable or disable SSL, see Configuring SSL.
You should be familiar with:
  • Computer basics.
  • Java programming language.
  • JDBC knowledge.
Download the SSL certificate and verify it before connecting to your instance.
If the ssl_type value of a database user is x509, this method is unavailable.
To check the ssl_type value of the current user, run the following command:
select ssl_type from mysql.user where user = 'xxx';
  1. Download the CA certificate or certificate bundle.
    1. On the Instances page, click the instance name to go to the Basic Information page.
    2. Click Download under SSL.
  2. Use keytool to generate a truststore file using the CA certificate.
    keytool_installation_path ./keytool.exe -importcert -alias MySQLCACert -­file ca.pem -keystore truststore_file -storepass password
    Table 1 Parameter description
    Bin directory in the JDK or JRE installation path, for example, C:\Program Files (x86)\Java\jdk­11.0.7\bin.
    MySQLCACert
    Name of the truststore file. Set it to a name specific to the service for future identification.
    ca.pem
    Name of the CA certificate downloaded and decompressed in 1, for example, ca.pem.
    truststore_file
    Path for storing the truststore file.
    password
    Password of the truststore file.
    Code example (using keytool in the JDK installation path to generate the truststore file):
    Owner:  CN=MySQL_Server_8.0.22_Auto_Generated_CA_Certificate
    Issuer: CN=MySQL_Server_8.0.22_Auto_Generated_CA_Certificate
    Serial number: 1
    Valid from: Thu Feb 16 11:42:43 EST 2017 until: Sun Feb 14 11:42:43 EST 2027
    Certificate fingerprints:
         MD5: 18:87:97:37:EA:CB:0B:5A:24:AB:27:76:45:A4:78:C1
         SHA1: 2B:0D:D9:69:2C:99:BF:1E:2A:25:4E:8D:2D:38:B8:70:66:47:FA:ED
         SHA256:C3:29:67:1B:E5:37:06:F7:A9:93:DF:C7:B3:27:5E:09:C7:FD:EE:2D:18:86:F4:9C:40:D8:26:CB:DA:95: A0:24
         Signature algorithm name: SHA256withRSA Subject Public Key Algorithm: 2048-bit RSA key
         Version: 1
         Trust this certificate? [no]: y
         Certificate was added to keystore
  3. Connect to your TaurusDB instance through JDBC.
    jdbc:mysql://instance_ip:instance_port/database_name?requireSSL=value1&useSSL=value2&verifyServerCertificate=value3&trustCertificateKeyStoreUrl=file: truststore_file&trustCertificateKeyStorePassword=password
    Table 2 Parameter description
    instance_ip
    IP address of the instance.
    • If you are accessing the instance through an ECS, instance_ip is the private IP address of the instance. You can view the private IP address in the Network Information area on the Basic Information page.
    • If you are accessing the instance through a public network, instance_ip is the EIP that has been bound to the instance. You can view the EIP in the Network Information area on the Basic Information page.
    • If you are accessing the instance through a proxy instance, instance_ip is the proxy address. You can view the proxy address on the Database Proxy page.
    instance_port
    Database port of the instance. The default port is 3306.
    You can view the database port in the Network Information area on the Basic Information page.
    database_name
    Database name used for connecting to the instance. The default value is mysql.
    value1
    Value of requireSSL, indicating whether the server supports SSL. It can be either of the following:
    • true: The server supports SSL.
    • false: The server does not support SSL.
    For details about the relationship between requireSSL and other connection parameters, as well as the relationship between requireSSL and sslMode, see Table 3.
    value2
    Value of useSSL, indicating whether the client uses SSL to connect to the server. It can be either of the following:
    • true: The client uses SSL to connect to the server.
    • false: The client does not use SSL to connect to the server.
    For details about the relationship between useSSL and other connection parameters, as well as the relationship between useSSL and sslMode, see Table 3.
    value3
    Value of verifyServerCertificate, indicating whether the client verifies the server certificate. It can be either of the following:
    • true: The client verifies the server certificate.
    • false: The client does not verify the server certificate.
    For details about the relationship between verifyServerCertificate and other connection parameters, as well as the relationship between verifyServerCertificate and sslMode, see Table 3.
    truststore_file
    Path for storing the truststore file configured in 2.
    password
    Password of the truststore file configured in 2.
    Table 3 Relationship between connection parameters and sslMode
    useSSL
    requireSSL
    sslMode
    false
    N/A
    N/A
    DISABLED
    true
    false
    false
    PREFERRED
    true
    true
    false
    REQUIRED
    true
    N/A
    true
    VERIFY_CA
    Code example (Java code for connecting to a TaurusDB instance):
    import java.sql.Connection;
    import java.sql.DriverManager;
    import java.sql.ResultSet;
    import java.sql.Statement;
    import java.sql.SQLException;
    public class JDBCTest {
      // There will be security risks if the username and password used for authentication are directly written into code. Store the username and password in ciphertext in the configuration file or environment variables.
      // In this example, the username and password are stored in the environment variables. Before running the example commands, set environment variables EXAMPLE_USERNAME_ENV and EXAMPLE_PASSWORD_ENV as needed.
        static final String USER = System.getenv("EXAMPLE_USERNAME_ENV");
        static final String PASS = System.getenv("EXAMPLE_PASSWORD_ENV");
            Connection conn = null;
            Statement stmt = null;
            String url = "jdbc:mysql://<instance_ip>:<instance_port>/<database_name>?
    requireSSL=true&useSSL=true&verifyServerCertificate=true&trustCertificateKeyStoreUrl=file:
    <truststore_file>&trustCertificateKeyStorePassword=<password>";
            try {
                Class.forName("com.mysql.cj.jdbc.Driver");
                conn = DriverManager.getConnection(url, USER, PASS);
                stmt = conn.createStatement();
                String sql = "show status like 'ssl%'";
                ResultSet rs = stmt.executeQuery(sql);
                int columns = rs.getMetaData().getColumnCount();
                for (int i = 1; i <= columns; i++) {
                    System.out.print(rs.getMetaData().getColumnName(i));
                    System.out.print("\t");
                while (rs.next()) {
                    System.out.println();
                        System.out.print(rs.getObject(i));
                rs.close();
                stmt.close();
                conn.close();
            } catch (SQLException se) {
                se.printStackTrace();
            } catch (Exception e) {
            } finally {
                // release resource ....
You do not need to download the SSL certificate because certificate verification on the server is not required.
  1. Connect to your TaurusDB instance through JDBC.
    jdbc:mysql://instance_ip:instance_port/database_name?useSSL=false
    Table 4 Parameter description
    instance_ip
    instance_port
    database_name
    public class MyConnTest {
    	final public static void main(String[] args) {
    		// set sslmode here.
    		// no ssl certificate, so do not specify path.
                    String url = "jdbc:mysql://<instance_ip>:<instance_port>/<database_name>?useSSL=false";
    		try {
    			Class.forName("com.mysql.jdbc.Driver");
                            conn = DriverManager.getConnection(url, System.getenv("EXAMPLE_USERNAME_ENV"), System.getenv("EXAMPLE_PASSWORD_ENV"));
    			System.out.println("Database connected");
    			Statement stmt = conn.createStatement();
    			ResultSet rs = stmt.executeQuery("SELECT * FROM mytable WHERE columnfoo = 500");
    			while (rs.next()) {
    				System.out.println(rs.getString(1));
    			rs.close();
    			stmt.close();
    			conn.close();
    			System.out.println("Test failed");
    		} finally {
Related Issues
  • Symptom
    When you use JDK 8.0 or a later version to connect to your TaurusDB instance with an SSL certificate downloaded, an error similar to the following is reported:
    javax.net.ssl.SSLHandshakeException: No appropriate protocol (protocol is disabled or
    cipher suites are inappropriate)
        at sun.security.ssl.HandshakeContext.<init>(HandshakeContext.java:171) ~[na:1.8.0_292]
        at sun.security.ssl.ClientHandshakeContext.<init>(ClientHandshakeContext.java:98) ~
    [na:1.8.0_292]
        at sun.security.ssl.TransportContext.kickstart(TransportContext.java:220) ~
    [na:1.8.0_292]
        at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:428) ~
    [na:1.8.0_292]
        at
    com.mysql.cj.protocol.ExportControlled.performTlsHandshake(ExportControlled.java:316) ~
    [mysql-connector-java-8.0.17.jar:8.0.17]
        at
    com.mysql.cj.protocol.StandardSocketFactory.performTlsHandshake(StandardSocketFactory.java
    :188) ~[mysql-connector-java-8.0.17.jar:8.0.17]
        at
    com.mysql.cj.protocol.a.NativeSocketConnection.performTlsHandshake(NativeSocketConnection.
    java:99) ~[mysql-connector-java-8.0.17.jar:8.0.17]
        at
    com.mysql.cj.protocol.a.NativeProtocol.negotiateSSLConnection(NativeProtocol.java:331) ~
    ... 68 common frames omitted
  • Solution
    Specify the corresponding parameter values in the code link of 3 based on the JAR package used by the client. Example:
    • mysql-connector-java-5.1.xx.jar (For connection drivers earlier than 8.0.28, use the enabledTLSProtocols parameter. For details, see Connecting Securely Using SSL.)
       truststore_file&trustCertificateKeyStorePassword=password& enabledTLSProtocols=TLSv1.2
    • mysql-connector-java-8.0. xx.jar (For connection drivers of 8.0.28 and later versions, use the tlsVersions parameter.)
       truststore_file&trustCertificateKeyStorePassword=password& tlsVersions =TLSv1.2
