Updated on 2025-11-14 GMT+08:00
Enabling SQL Audit
After SQL audit is enabled for TaurusDB for PostgreSQL instances, the system records SQL operations and uploads logs every half an hour or when the size of a single record reaches 100 MB. The generated audit logs are stored in OBS. If there is not enough free backup space available for generated audit logs, the additional space required is billed.
Precautions
  • SQL audit is disabled for DB instances by default because enabling it increases database loads.
  • To ensure good performance, SQL audit uses the Coordinated Universal Time (UTC) format and is not affected by the time zone configuration.
  • To enable SQL audit, you need to install the pgAudit extension and set related parameters based on the pgAudit extension usage instruction.
Only the latest minor version of TaurusDB for PostgreSQL 16 supports SQL audit. To use this function, submit a service ticket.
Performance
The pgAudit impact on database performance depends on how many audit logs there are and how often they are generated. More audit logs mean more impact on the database performance. pgAudit can decrease the database performance by about 20%. You need to configure parameters for pgAudit based on your workloads to achieve a balance between audit requirements and database performance.
  2. Click in the upper left corner and select a region.
  3. Click in the upper left corner of the page and choose Databases > TaurusDB.
  4. On the Instances page, click the instance name.
  5. In the navigation pane, choose SQL Audits. On the displayed page, click Set SQL Audit.
  6. In the displayed dialog box, set the number of days for storing SQL audit logs and click OK.
    Audit logs can be retained from 1 to 732 days and are retained for 7 days by default.
    Figure 1 Setting SQL audit
  7. To disable SQL audit, toggle off the Audit Logging switch, select the confirmation check box, and click OK.
    After SQL audit is disabled, all audit logs will be deleted immediately and cannot be recovered. Exercise caution when performing this operation.
    Figure 2 Disabling SQL audit
