Updated on 2026-01-15 GMT+08:00
Modifying a Parameter Template Description
You can modify the description of a parameter template you have created.
You cannot modify the description of a default parameter template.
  2. Click in the upper left corner and select a region.
  3. Click in the upper left corner of the page and choose Databases > TaurusDB.
  4. On the Parameter Templates page, click Custom Templates. Locate the target parameter template and click in the Description column.
  5. Enter a new description and click OK to submit the modification or click Cancel to cancel the modification.
    • The description consists of a maximum of 256 characters and cannot contain carriage return characters or the following special characters: >!<"&'=
    • After the modification is successful, you can view the new description in the Description column of the parameter template list.
