pg_stat_statements
Introduction
The pg_stat_statements extension provides a means for tracking planning and execution statistics of all SQL statements executed by a server.
For more information, see pg_stat_statements in the PostgreSQL documentation.
Supported Versions
You can run the following SQL statement to check whether your DB instance supports this extension:
SELECT * FROM pg_available_extension_versions WHERE name = 'pg_stat_statements';
To see more extensions supported by TaurusDB for PostgreSQL, go to Supported Extensions.
Extension Installation and Uninstallation
To check whether pg_stat_statements is installed in a database, run the following SQL statement:
select * from pg_extension where extname = 'pg_stat_statements';
If the command output is empty, the extension is not installed. If the extension information is displayed, the extension is installed.
By default, pg_stat_statements is preloaded in the shared_preload_libraries parameter. Perform the following steps to install or delete the extension:
- Installing the extension
SELECT control_extension('create', 'pg_stat_statements'); - Deleting the extension
SELECT control_extension('drop', 'pg_stat_statements');
For more information, see Installing and Uninstalling an Extension on the TaurusDB Console and Installing and Uninstalling an Extension Using SQL Commands.
Basic Functions
- After the pg_stat_statements extension is installed, configure the parameters below. You can adjust the values based on your workload requirements.
Table 1 Parameter description Parameter
Reboot Required
Default Value
Allowed Values
pg_stat_statements.max
Yes
5000
100-5,000,000
Specifies the maximum number of statements tracked by pg_stat_statements.
pg_stat_statements.save
No
on
on, off
Specifies whether to save statement statistics across server shutdowns.
pg_stat_statements.track
No
top
top, all, none
Controls which statements are counted by pg_stat_statements.
pg_stat_statements.track_planning
No
off
on, off
Controls whether planning duration is tracked by pg_stat_statements.
pg_stat_statements.track_utility
No
on
on, off
Controls whether utility commands are tracked by pg_stat_statements.
- Query the pg_stat_statements view to obtain statistics.
select * from pg_stat_statements;
- Query the SQL statements with high I/O consumption.
select userid::regrole, dbid, query from pg_stat_statements order by (blk_read_time+blk_write_time) desc limit 5;
- Query the SQL statements with high consumption of shared memory.
select userid::regrole, dbid, query from pg_stat_statements order by (shared_blks_hit+shared_blks_dirtied) desc limit 5;
- Reset the statistics.
select pg_stat_statements_reset();
Advanced Functions
You can use pg_stat_statements to troubleshoot high CPU usage. The procedure is as follows:
- Reset the pg_stat_statements counter.
Leave enough time for pg_stat_statements to collect information.
- Obtain the most time-consuming SQL statements.
select * from pg_stat_statements order by total_exec_time desc limit 10;
The obtained SQL statements have been occupying the user-mode CPU for a long time. Analyze these SQL statements.
- Obtain the SQL statements that read the buffer for the most times.
select * from pg_stat_statements order by shared_blks_hit + shared_blks_read desc limit 10;
The obtained SQL statements may cause too many buffer reads due to a lack of indexes, consuming a large number of CPU resources.
- Obtain the SQL statements that have been executed for the most times.
select * from pg_stat_statements order by calls desc limit 10;
It takes a short time to execute some simple SQL statements separately. However, in some cases (for example, cyclic executions in a transaction or concurrent executions), the CPU usage increases.
