Updated on 2025-11-14 GMT+08:00
Restoring a DB Instance from Backups
You can use an automated or manual backup to restore data to the state at the time when the backup was created. The restoration is at the DB instance level.
Function Description
Table 1 Function description
Item
Restoration scope
The entire instance
Instance data after restoration
The instance data after restoration is consistent with that in the full backup used for the restoration.
  • Restoring data to a new instance creates an instance with the same data as that in the backup.
  • Restoring data to an existing instance will overwrite the instance data.
Restoration type
  • Restoration to a new instance
  • Restoration to the original instance
  • Restoration to an existing instance other than the original one
Configurations for restoring to a new instance
  • The DB engine and engine version of the new instance are the same as those of the original instance.
  • The storage space of the new instance is the same as that of the original instance by default and the new instance must be at least as large as the original instance.
  • Other parameters need to be reconfigured.
Time required
The time required depends on how much data there is in the instance. The average restoration speed is 40 MB/s.
  • You can restore to new DB instances from backups only when your account balance is greater than or equal to $0 USD. You will pay for the new instance specifications.
  • TaurusDB for PostgreSQL supports restoration to the original DB instance from backups. To use this function, submit a service ticket.
  • Constraints on restoring data to a new DB instance:
    The new DB instance must use the same Babelfish migration mode as the original DB instance.
  • Constraints on restoring data to the original DB instance:
    • If the DB instance for which the backup is created has been deleted, data cannot be restored to the original DB instance.
    • Restoring to the original DB instance will overwrite data on it and cause the DB instance to be unavailable during the restoration.
  • Constraints on restoring data to an existing DB instance (other than the original instance):
    • If the target existing DB instance has been deleted, data cannot be restored to it.
    • Restoring to an existing DB instance will overwrite data on it and cause the existing DB instance to be unavailable.
    • To restore backup data to an existing DB instance, the selected DB instance must have the same DB engine, version, and Babelfish migration mode as the original DB instance.
    • Ensure that the storage space of the selected DB instance is greater than or equal to the storage space of the original DB instance. Otherwise, data will not be restored.
  2. Click in the upper left corner and select a region.
  3. Click in the upper left corner of the page and choose Databases > TaurusDB.
  4. On the Backups page, select the backup to be restored and click Restore in the Operation column.
    Alternatively, click the target DB instance on the Instances page. In the navigation pane, choose Backups. On the displayed page, select the backup to be restored and click Restore in the Operation column.
  5. Select a restoration method and click OK.
    Figure 1 Restoring to a new DB instance
    • Create New Instance
      The Create New Instance page is displayed.
      • Storage space of the new DB instance is the same as that of the original DB instance by default and the new instance must be at least as large as the original DB instance.
      • Other settings are the same as those of the original DB instance by default and can be modified. For details, see Buying a TaurusDB for PostgreSQL Instance.
    • Restore to Original
      1. Select "I acknowledge that after I select Restore to Original, data on the original databases will be overwritten and the original DB instance will be unavailable during the restoration." and click Next.
      2. Confirm the information and click OK.
    • Restore to Existing
  6. View the restoration result. The result depends on which restoration method was selected:
      A new instance that contains the same data as the backup is created. When the instance status changes from Creating to Available, the restoration is complete.
      The new instance is independent from the original one.
      After the new instance is created, a full backup will be automatically triggered.
      On the Instances page, when the instance status changes from Restoring to Available, the restoration is complete. After the restoration, a full backup will be automatically triggered.
