Recycling a DB Instance
TaurusDB for PostgreSQL allows you to move deleted pay-per-use DB instances to the recycle bin. You can rebuild a DB instance that was deleted up to 7 days ago from the recycle bin.
If resources are not renewed after expiration, you can rebuild DB instances from the recycle bin to restore data.
- The recycle bin is free for use.
- The recycle bin is enabled by default and cannot be disabled.
- After you submit a deletion request for your DB instance, a full backup will be performed. You can rebuild the DB instance only after the full backup is complete.
Modifying Recycling Policy
Instances in the recycle bin are retained for 7 days by default. A new recycling policy only applies to DB instances that were put in the recycle bin after the new policy was put into effect. For DB instances that were in the recycle bin before the modification, the original recycling policy takes effect.
- Click
in the upper left corner and select a region. - Click
in the upper left corner of the page and choose Databases > TaurusDB. - In the navigation pane, choose Recycle Bin.
- On the Recycle Bin page, click Modify Recycling Policy. In the displayed dialog box, set the retention period for the deleted DB instances to 1 to 7 days.
- Then, click OK.
Figure 1 Modifying the recycling policy
Rebuilding a DB Instance
You can rebuild the primary DB instances in the recycle bin within the retention period.
- Click
- On the Recycle Bin page, locate the target DB instance to be rebuilt and click Rebuild in the Operation column.
- On the Rebuild DB Instance page, configure required information and submit the rebuild task. For details, see Restoring a DB Instance from Backups.
