Help Center/ TaurusDB_TaurusDB for PostgreSQL/ User Guide/ Database Migration/ Migrating a Microsoft SQL Server Database to TaurusDB for PostgreSQL Using Babelfish
Updated on 2025-11-14 GMT+08:00
This section describes how to migrate a Microsoft SQL Server database to TaurusDB for PostgreSQL. Babelfish's compatibility with Microsoft SQL Server helps minimize the need for code adaptation, streamline the migration process, improve efficiency, and save resources.
  • You have deployed a TaurusDB for PostgreSQL instance with Babelfish enabled.
  • You have created a Babelfish account.
  • You have configured an IP address whitelist to allow the server where the client is located to access the target instance.
  • You have installed a Microsoft SQL Server client tool (for example, sqlcmd).
  • You have enabled Huawei Cloud Data Replication Service (DRS) if you plan to migrate data using it.
