Help Center/ TaurusDB_TaurusDB for PostgreSQL/ User Guide/ Using IAM to Grant Access to TaurusDB for PostgreSQL/ Creating a User and Granting TaurusDB for PostgreSQL Permissions
Updated on 2025-11-14 GMT+08:00
This chapter describes how to use Identity and Access Management (IAM) for fine-grained permissions management for your TaurusDB for PostgreSQL resources. With IAM, you can:
  • Create IAM users for employees based on your enterprise's organizational structure. Each IAM user has their own identity credentials for accessing TaurusDB for PostgreSQL resources.
  • Grant only the permissions required for users to perform a specific task.
  • Entrust a Huawei Cloud account or cloud service to perform efficient O&M on your TaurusDB for PostgreSQL resources.
If your Huawei Cloud account does not require individual IAM users, skip this chapter.
This section describes the procedure for granting permissions (see Figure 1).
Before assigning permissions to user groups, you should learn about TaurusDB for PostgreSQL system-defined policies and select the policies as required. For the system-defined policies of other services, see System-defined Policies/Roles.
Process Flow
Figure 1 Process for granting TaurusDB for PostgreSQL permissions
  1. Create a user group and assign permissions to it.
    Create a user group on the IAM console and attach the TaurusDB FullAccess policy to the group.
    To use some interconnected services, you also need to configure permissions of such services.
    For example, to connect to your DB instance through the console, configure the DAS FullAccess permission of Data Admin Service (DAS) besides TaurusDB FullAccess.
  2. Create an IAM user and add it to the user group.
    Create a user on the IAM console and add the user to the group created in 1.
  3. Log in and verify permissions.
    Log in to the TaurusDB console by using the created user, and verify that the user only has read permissions for TaurusDB for PostgreSQL.
    Choose Service List > TaurusDB and click Buy DB Instance. If you can buy a TaurusDB for PostgreSQL instance, the required permission policy has already been applied.
