Using IAM Roles or Policies to Allow Access to SWR
System-defined permissions in role/policy-based authorization provided by Identity and Access Management (IAM) let you control access to your SWR resources. With IAM, you can:
- Create IAM users or user groups for personnel based on your enterprise's organizational structure. Each IAM user has their own identity credentials for accessing SWR resources.
- Grant users only the permissions required to perform a given task based on their job responsibilities.
- Entrust other Huawei Cloud account or cloud service to perform efficient O&M on your SWR resources.
If your account does not require individual IAM users for permissions management, you can skip this section.
Figure 1 shows the process flow of role/policy-based authorization.
Before granting permissions to user groups, learn about system-defined permissions for SWR. For details, see Permissions. To grant permissions for other services, learn about all system-defined permissions.
Process Flow
- Create a user group and assign permissions to it.
Create a user group on the IAM console, and grant the SWR Admin permissions to the group.
- Create an IAM user and add it to the user group.
Create a user on the IAM console and add the user to the group created in 1.
- Log in and verify permissions.
Log in to the management console using the IAM user. Switch to the authorized region. If the following operations can be performed, the permissions are assigned successfully:
- Choose Service List > SoftWare Repository for Container. The SWR console is displayed.
- In the navigation pane, choose Organizations. Click Create Organization in the upper right corner. Enter an organization name to create an organization.
- In the navigation pane, choose My Images. Click Upload Through SWR in the upper right corner. Select the new organization. Upload a local image file to SWR.
SWR Resources
A resource is an object that exists within a service. SWR resources include organizations and images. When creating a policy, you can select a resource by specifying its path.
Resource |
Resource Name |
Path |
repo |
Image repository |
[Format] swr:*:*:repo:image repository name The first * is regionid, and the second * is domainid. [Note] IAM automatically generates the path prefix swr:*:*:repo:. For the path of a specific repository, add the image repository name to the end. You can also use a wildcard character (*) to indicate any image repository. Example: swr:*:*:repo:test/nginx*: image repository whose name starts with nginx in the test organization swr:*:*:repo:test/nginx: image repository whose name is nginx in the test organization |
namespace |
Organization |
[Format] swr:*:*:namespace:organization name The first * is regionid, and the second * is domainid. [Note] For the path of an organization, IAM automatically generates the resource path prefix swr:*:*:namespace:. You can add the organization name to the end. You can also use a wildcard character (*) to indicate any organization. Example: swr:*:*:namespace:test*: organization whose name starts with test swr:*:*:namespace:test: organization whose name is test |
Example 1: If you only allow users to query brief information about image repositories, configure a policy as follows:
"Version": "5.0"
"Statement": [
"Effect": "Allow",
"Action": [
"swr:repo:getRepo"
"Resource": [
"swr:*:*:repo:*"
Example 2: To synchronize an image test from the source organization in the cn-north-4 region to the target organization in the cn-north-7 organization, a user needs to have permission to create auto image synchronization tasks and pull images in the cn-north-4 region, permission to obtain temporary login commands in the cn-north-4 and cn-north-7 regions, and permission to push images in the cn-north-7 region. Configure a policy as follows:
"Version": "5.0",
"Statement": [
"Effect": "Allow",
"Action": [
"swr:repo:createAutoSyncRepoJob",
"swr:repo:download"
"Resource": [
"swr:cn-north-4:*:repo:source/test"
"Effect": "Allow",
"Action": [
"swr:repo:upload"
"Resource": [
"swr:cn-north-7:*:repo:target"
"Effect": "Allow",
"Action": [
"swr::createLoginSecret"
