Viewing Events of a Batch Service
During the whole lifecycle of a service, every key event is automatically recorded. You can view the events on the details page of the service at any time.
This helps you better understand the service deployment and running process and accurately locate faults when a task exception occurs. You can check the following events:
Event Type |
Event (xxx should be replaced with the actual value.) |
Solution |
Normal |
The service starts to deploy. |
N/A |
Abnormal |
Insufficient resources. Wait until idle resources are sufficient. |
Wait until the resources are released and try again. |
Abnormal |
Insufficient xxx. The scheduling failed. Supplementary information: xxx |
Learn about resource insufficiency details based on the supplementary information. For details, see FAQs. |
Normal |
The image starts to create. |
N/A |
Abnormal |
Failed to create model image xxx. For details, see logs :\nxxx. |
Locate and rectify the fault based on the build logs. |
Abnormal |
Failed to create the image. |
Contact technical support. |
Normal |
The image is created. |
N/A |
Abnormal |
Service xxx failed. Error: xxx |
Locate and rectify the fault based on the error information. |
Abnormal |
Failed to update the service. Perform a rollback. |
Normal |
The service is being updated. |
N/A |
Normal |
The service is being started. |
N/A |
Normal |
The service is being stopped. |
N/A |
Normal |
The service has been stopped. |
N/A |
Normal |
Auto stop has been disabled. |
N/A |
Normal |
Auto stop has been enabled. The service will stop after xs. |
N/A |
Normal |
The service stops when the auto stop time expires. |
N/A |
Abnormal |
The service is stopped because the quota exceeds the upper limit. |
Abnormal |
Failed to automatically stop the service. Error: xxx |
Normal |
Service instances deleted from resource pool xxx. |
N/A |
Normal |
Service instances stopped in resource pool xxx. |
N/A |
Abnormal |
The batch service failed. Try again later. Error: xxx |
Normal |
The service has been executed. |
N/A |
Abnormal |
Failed to stop the service. Error: xxx |
Normal |
The subscription license xxx is to expire. |
N/A |
Normal |
Service xxx started. |
N/A |
Abnormal |
Failed to start service xxx. |
For details about how to locate and rectify the fault, see FAQs. |
Abnormal |
Service deployment timed out. Error: xxx |
Normal |
Failed to update the service. The update has been rolled back. |
N/A |
Abnormal |
Failed to update the service. The rollback failed. |
Normal |
[model 0.0.1] OBS bucket, OBS parallel file system, or SFS Turbo mounted successfully. [%s] %s volume successfully. |
N/A |
During service deployment and running, key events can both be manually and automatically refreshed.
Viewing Events
- In the navigation pane of the ModelArts console, choose Model Deployment > Batch Services. In the service list, click the name or ID of the target service to go to its details page.
- View the events in the Events tab.
