On this page
Show all
Viewing Events of a Real-Time Service
Updated on 2024-12-26 GMT+08:00
During the whole lifecycle of a service, every key event is automatically recorded. You can view the events on the details page of the service at any time.
This helps you better understand the service deployment and running process and accurately locate faults when a task exception occurs. You can check the following events:
Table 1 Events
Event Type
Event (xxx should be replaced with the actual value.)
Solution
Normal
The service starts to deploy.
N/A
Abnormal
Insufficient resources. Wait until idle resources are sufficient.
Wait until the resources are released and try again.
Abnormal
Insufficient xxx. The scheduling failed. Supplementary information: xxx
Learn about resource insufficiency details based on the supplementary information. For details, see FAQs.
Normal
The image starts to create.
N/A
Abnormal
Failed to create model image xxx. For details, see logs :\nxxx.
Locate and rectify the fault based on the build logs.
Abnormal
Failed to create the image.
Contact technical support.
Normal
The image is created.
N/A
Abnormal
Service xxx failed. Error: xxx
Locate and rectify the fault based on the error information.
Abnormal
Failed to update the service. Perform a rollback.
Normal
The service is being updated.
N/A
Normal
The service is being started.
N/A
Normal
The service is being stopped.
N/A
Normal
The service has been stopped.
N/A
Normal
Auto stop has been disabled.
N/A
Normal
Auto stop has been enabled. The service will stop after xs.
N/A
Normal
The service stops when the auto stop time expires.
N/A
Abnormal
The service is stopped because the quota exceeds the upper limit.
Abnormal
Failed to automatically stop the service. Error: xxx
Normal
Service instances deleted from resource pool xxx.
N/A
Normal
Service instances stopped in resource pool xxx.
N/A
Abnormal
The batch service failed. Try again later. Error: xxx
Normal
The service has been executed.
N/A
Abnormal
Failed to stop the service. Error: xxx
Normal
The subscription license xxx is to expire.
N/A
Normal
Service xxx started.
N/A
Abnormal
Failed to start service xxx.
For details about how to locate and rectify the fault, see FAQs.
Abnormal
Service deployment timed out. Error: xxx
Normal
Failed to update the service. The update has been rolled back.
N/A
Abnormal
Failed to update the service. The rollback failed.
Normal
[model 0.0.1] OBS bucket, OBS parallel file system, or SFS Turbo mounted successfully.
[%s] %s volume successfully.
N/A
During service deployment and running, key events can both be manually and automatically refreshed.
Viewing Events
  1. In the navigation pane of the ModelArts console, choose Model Deployment > Real-Time Services. In the service list, click the name or ID of the target service to go to its details page.
  2. View the events in the Events tab.
