Updated on 2026-02-13 GMT+08:00
Viewing Monitoring Metrics of a Training Job
Receiving and promptly addressing alarms during a training job (for example, abnormal loss values) can save significant time and resources, preventing the waste caused by invalid job runs. Additionally, metric monitoring allows you to track the training job's progress in real time and the model's training status across different phases.
In the Monitoring tab of the training job details page of ModelArts Standard, you can view the CPU, GPU, or NPU usage of training jobs. For details, see Viewable Metrics on the ModelArts Console.
For more metrics, go to the AOM console. For details, see Viewing All ModelArts Monitoring Metrics on the AOM Console.
With ModelArts, you can track custom metrics in AOM, such as loss values, step durations, and GPU throughput. These metrics are displayed in your training logs, making it easy to monitor trends and compare results across different jobs.
Reporting Custom Metrics to AOM Using SDK: Integrate the SDK into your code to upload metric data to AOM manually.
  • This method works well for users who need to add custom metrics, like adding custom dimensions or complex calculations.
  • This method works well for complex service logic and when you need to control metric reporting in your code.
  • This method works well for users who have experience with Huawei Cloud SDKs and know about cloud services.
Table 1 shows the metrics that can be viewed on the training job details page of the ModelArts console.
Table 1 shows the training metrics that can be viewed on the Overview page of the ModelArts console.
Table 1 Task-level metrics of training jobs
Metric
How to View
Training job resource usage
CPU, GPU, or NPU usage of a training job.
ModelArts console > Overview > Resource Usage of Training Jobs
Card-hours
Running duration and number of cards used by a training job.
This method works well for users who need to add custom metrics, like adding custom dimensions or complex calculations. It also works well for complex service logic and when you need to control metric reporting in your code.
  1. Add the metric monitoring code to the training code. You can refer to the sample code below. For details about other requirements for preparing training code, see Preparing Model Training Code.
    Replace the region value cn-southwest-2 in the last but one line of the code with the actual region. For details about the region values, see Endpoints.
    Add monitoring metrics to the code. For details about the parameters, see the AOM documentation.
    # coding: utf-8
    import os
    from huaweicloudsdkaom.v2 import *
    from huaweicloudsdkaom.v2.region.aom_region import AomRegion
    from huaweicloudsdkcore.auth.credentials import BasicCredentials
    from huaweicloudsdkcore.exceptions import exceptions
    from moxing.framework import cloud_utils
    def report2Aom(request,region):
        auth = cloud_utils.get_auth() # AK, SK, and temporary token, which are automatically obtained by the system.
        ak = auth.AK
        sk = auth.SK
        securityToken = auth.TOKEN
        projectId = os.environ.get("MA_IAM_PROJECT_ID")
        credentials = BasicCredentials(ak, sk, projectId).with_security_token(securityToken)
        client = AomClient.new_builder() \
            .with_credentials(credentials) \
            .with_region(AomRegion.value_of(region)) \
            .build()
        try:
            response = client.add_metric_data(request)
            print(response)
        except Exception as e:
            print(e)
    if __name__ == "__main__":
        request = AddMetricDataRequest()
        listValuesBody = [
            # Enter the metric name, type, unit, and value, such as step_time and loss value.
            ValueData(
                metric_name="step_time", # Monitoring metric name, for example, step_time
                type="float",  # Data type of the metric. The value can only be int or float.
                unit="ms",     # Data unit, for example, ms. The value contains a maximum of 32 characters.
                value=135.572  # Value of the metric data. The value must be of a valid numeric type. The minimum value is 0.
            ValueData(
                metric_name="loss",
                type="float",
                value=0.6932
        listDimensionsMetric = [
            # Enter the metric dimensions you want to view, such as thread and host.
            Dimension2(
                name="cluster_name",# This is only an example. Replace it with the actual metric dimension you want to view.
                value="fab2c5cf438b4f0c851fdcdf"# This is only an example. Replace it with the actual parameter value.
            Dimension2(
                name="user_name",
                value="modelarts_02" # This is only an example. Replace it with the actual parameter value.
            Dimension2(
                name="user_id",
                value="04f258c8fb00d42a1f6xxx" # This is only an example. Replace it with the actual parameter value.
        metricBody = MetricItemInfo(
            dimensions=listDimensionsMetric,
            namespace="NOPAAS.ESC"  # Retain the default value.
        listBodybody = [
            MetricDataItem(
                collect_time=int(round(time.time()*1000)),  # Time when monitoring metric data is collected. The value is the latest timestamp, in milliseconds.
                metric=metricBody,
                values=listValuesBody
        request.body = listBodybody
        region = "cn-southwest-2"  # Replace the value with the actual region.
        response = report2Aom(request,region)
  2. Add the commands below to the training code to load the required dependency packages. If a custom image is used, you can also install the dependencies during image creation. For details, see Developing Code for Training Using a Custom Image.
    pip install huaweicloudsdkaom
    pip install huaweicloudsdkcore
  3. Create and run a training job. For details, see Creating a Production Training Job (Old Version).
  4. Log in to the AOM console. On the Metric Browsing page, view the reported metric data by specifying metrics.
  5. Set the AOM alarm and notification mechanisms by referring to Configuring Alarm Settings.
