Help Center/ Simple Message Notification/ User Guide/ Topic Management/ Modifying the Display Name of a Topic
Updated on 2025-08-19 GMT+08:00
You have created a topic and want to modify its display name.
  2. In the upper left corner of the page, click and select the desired region and project.
  3. Click . Select Management & Governance > Simple Message Notification.
    The SMN console is displayed.
  4. In the navigation pane on the left, choose Topic Management > Topics.
    The Topics page is displayed.
  5. Locate the topic, choose More > Modify Display Name in the Operation column. In the displayed Modify Display Name dialog box, enter a new display name.
    Alternatively, locate the topic and click its name. In the Topic Details area, click and enter a new display name.
    After you specify a display name, the sender in email messages will be presented as Display Name<username@example.com>. Otherwise, the sender will be username@example.com.
  6. Click OK.
