Creating a Subscriber
On the Subscribers page, you can centrally manage subscriber information across regions. You can create multiple subscribers and batch subscribe them to a topic.
This section describes how you can create a subscriber.
Subscriber data from the regions within the Chinese mainland is stored in the CN North-Beijing4 region while subscriber data from the regions outside the Chinese mainland is stored in the CN-Hong Kong region.
- Log in to the SMN console.
- In the navigation pane on the left, choose Subscribers.
- On the Subscribers page, click Create Subscriber in the upper right corner.
The Create Subscriber page appears.
Figure 1 Create Subscriber
- Configure the parameters based on Table 1.
Table 1 Parameters for creating a subscriber Parameter
Name
Specifies the subscriber name.
Protocol
Specifies the protocol over which messages are sent. The following protocols are supported: SMS, Email, HTTP, and HTTPS.
NOTE:If SMS or Email is selected for Protocol, you can select Add from IAM. You can then select subscription endpoints from IAM users.
Endpoint
Specifies the subscription endpoint. You can enter SMS, email, HTTP, and HTTPS endpoints in batches. Enter one endpoint per line. You can enter a maximum of 10 endpoints.
- SMS: Enter one or more valid phone numbers.
Examples:
18512345678
+8618512345678
- Email: Enter one or more valid email addresses.
Examples:
username@example.com
username2@example.com
- HTTP: Enter one or more public network URLs.
Example:
http://example.com/notification/action
- HTTPS: Enter one or more public network URLs.
Example:
https://example.com/notification/action
Request Header
This parameter is available when you select HTTP or HTTPS for Protocol. Specify Key and Value for the request header.
The value of Key must meet the following requirements:
- The value is case insensitive and must be unique.
- The value must start with x- but cannot start with x-smn.
- The value can contain only letters, digits, and hyphens (-). The value cannot end with a hyphen nor contain consecutive hyphens.
Group
Specifies the group of the subscriber.
- Click OK.
Follow-Up Operations
After you create a subscriber and the subscriber confirms the subscription, you can import the subscription to your region.
- Select the region and topic to which the subscription is to be imported and click Add Subscription. Figure 2 Add Subscription
- Select Import subscribers for Method and select the created subscriber.
A confirmed subscription is added to the topic.
Figure 3 Subscription confirmed
