- What's New
- Function Overview
- Getting Started
User Guide
- Topic Management
- Subscription Management
- Message Template Management
- SMN Operation Recording
- Cloud Eye Monitoring
- Logs
- Permissions Management
- Quotas
- Appendix
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- APIs
- Examples
- Public Parameters
- Out-of-Date APIs
- Appendix
- SDK Reference
- What Are the Advantages of SMN?
- What Protocols Does SMN Support?
- How Is SMN Billed?
- What Are the Requirements for an SMN Topic Name?
- How Many Topics Can I Create?
- How Many Subscriptions Can Be Added to a Topic?
- How Many Messages Can Be Published to a Topic?
- How Many Message Templates Can I Create?
- What Are the Limitations on SMS Messages?
- Can I Add Subscriptions Using Multiple Protocols to a Topic?
- Can a Topic Creator Change Subscription Protocols in a Topic?
- Can I Change a Subscription Endpoint for a Topic?
- Can I Delete a Published Message?
- Does SMN Ensure That Messages Are Received by Subscription Endpoints?
- Will a Subscriber Receive the Same Message Multiple Times?
- Why Do Subscribers Fail to Receive Messages After I Publish Messages to a Topic?
- What Can I Do When Pictures in an Email Message Cannot Be Displayed?
- Does SMN Always Use the Same Phone Number or Sender Name to Send SMS Messages?
- How Do I Obtain My Account ID?
- How Does a DingTalk, Internal DingTalk, Lark, or WeCom Chatbot Obtain Subscription Endpoints?
- Videos
More Documents
- Overview
- Getting Started
- Topic Management
- Logs
- Quotas
- Appendix
- Change History
- API Reference
User Guide (Paris Region)
- Overview
- Getting Started
- Topic Management
- Logs
- Quotas
- Appendix
- Change History
- API Reference (Paris Region)
- Overview
- Getting Started
- Topic Management
- Logs
- Quotas
- Appendix
- Change History
- API Reference (Kuala Lumpur Region)
User Guide (Ankara Region)
- Overview
- Getting Started
- Topic Management
- Quotas
- Appendix
- Change History
- API Reference (Ankara Region)
Show all
Adding a Subscription
To enable an endpoint to receive messages published to a topic, you must subscribe the endpoint to the topic. The endpoint can be a phone number, email address, or an HTTP/HTTPS URL. After you subscribe an endpoint to a topic and the subscription is confirmed, the endpoint can receive messages published to the topic.
You can add multiple subscriptions to a topic. This section describes how to add a subscription to a topic you created or a topic that you have permissions for.
- In the upper left corner of the page, click
and select the desired region and project.
- Click
. Select Simple Message Notification under Management & Governance.
The SMN console is displayed.
- In the navigation pane on the left, choose Topic Management > Subscriptions.
- In the upper right corner, click Add Subscription.
The Add Subscription dialog box is displayed.
Figure 1 Add Subscription - Specify the required subscription information.
- Beside Topic Name, click Select Topic.
- Specify the subscription protocol and endpoints.
Table 1 Parameters for adding a subscription Parameter
Topic Name
Specifies the name of the topic to which messages are published.
Protocol
Specifies the protocol over which messages are sent. Possible values are SMS, HTTP, HTTPS, FunctionGraph (function), Voice notification, DingTalk chatbot, WeCom chatbot, Lark chatbot, and Email.
- DingTalk chatbot, voice notification, WeCom chatbot, and Lark chatbot are in the open beta test (OBT). To use any of these, submit a service ticket to apply for the OBT.
- After the OBT is enabled, the current token will be invalid. Log in to the console again, and a new token will be generated.
- The number of WeCom, DingTalk, or Lark messages that can be sent is limited, and the recipient system may be faulty.
In this case, SMN cannot ensure successful message delivery.
Endpoint
Specifies the subscription endpoint. You can add up to 10 SMS, email, HTTP, or HTTPS endpoints, one in each line.
- SMS: Enter one or more valid phone numbers.
Examples:
18512345678
+8618512345678
- Email: Enter one or more valid email addresses.
Examples:
username@example.com
username2@example.com
- HTTP: Enter one or more public network URLs.
Example:
http://example.com/notification/action
- HTTPS: Enter one or more public network URLs.
Example:
https://example.com/notification/action
- FunctionGraph (function): Click
to select a function and specify its version.
- Voice notification: Enter one or more valid phone numbers.
A phone number must be preceded by a plus sign (+) and a country code. If you enter a phone number used in the Chinese mainland, the plus sign (+) and the country code are not required.
Voice subscriptions are only available in some regions of the Chinese mainland. Voice notification is not supported in Hong Kong, Macao, Taiwan, Xinjiang, and Tibet.
Request Header
This parameter is only available if HTTP or HTTPS is selected for Protocol. It indicates whether to configure the request header now. If you select Configure now, specify Key and Value. You can add up to 10 request headers.
The value of Key must:
- be case insensitive and unique.
- start with x- but cannot start with x-smn.
- contain only digits, letters, and hyphens (-), but not end with a hyphen nor contain consecutive hyphens.
Availability Test
This parameter is only available if HTTP or HTTPS is selected for Protocol. Click Start to check the real-time connectivity between SMN and HTTP/HTTPS endpoints.
Version
This parameter is only available if FunctionGraph (function) is selected for Protocol. Select the version for the function. For details about how to create a version, see Managing Versions.
Specifies the remarks of the subscription.
(Optional) Configure a subscription filtering policy to limit the scope of message publishing.
The default filtering policy applies to message attributes. If you have set a filtering policy and message attributes when publishing a message, the system determines whether to push the messages to subscribers based on the filtering policy.
Subscription filtering policies are configured in JSON. The following is an example.{ "filter_polices": [ { "name": "policy_name", "string_equals": [ "policy_value" ] } ] }
- Click OK.
The subscription you added is displayed in the subscription list.
- To prevent malicious users from attacking subscription endpoints, SMN limits the number of confirmation messages that can be sent to an endpoint within a specified period. For details, see section "Traffic Control on Subscription Confirmation" in Simple Message Notification User Guide.
- SMN does not check whether subscription endpoints exist when you add subscriptions.
- After you add a subscription or request subscription confirmation, SMN will send a confirmation message to the endpoints, and the link in the confirmation message will be valid for 48 hours.
- Subscription confirmation messages will be counted as messages sent and will be billed.
