Help Center/ Scalable File Service Turbo/ User Guide/ Data Migration/ Migrating Local Data to SFS Turbo Using Direct Connect
Updated on 2024-12-23 GMT+08:00
Context
You can migrate data from a local NAS to SFS Turbo using Direct Connect.
In this solution, a Linux ECS is created to connect the local NAS and SFS Turbo, and data is migrated to the cloud using this ECS.
You can also refer to this solution to migrate data from an on-cloud NAS to SFS Turbo. For details, see Migrating Data from On-Cloud NAS to SFS Turbo.
Notes and Constraints
  • Only Linux ECSs can be used to migrate data.
  • The UID and GID of your file will no longer be consistent after data migration.
  • The file access modes will no longer be consistent after data migration.
  • Incremental migration is supported, so you can only migrate the changed data.
  • You have purchased and configured Direct Connect. For details, see Direct Connect User Guide.
  • You have created a Linux ECS.
  • You have created an SFS Turbo file system and obtained its shared path.
  • You have obtained the shared path of the local NAS.
  1. Log in to the ECS console.
  2. Log in to the Linux ECS.
  3. Mount the local NAS to the ECS.
    mount -t nfs -o vers=3,timeo=600,noresvport,nolock,tcp <Shared path of the local NAS> /mnt/src
  4. Mount the SFS Turbo file system to the ECS.
    mount -t nfs -o vers=3,timeo=600,noresvport,nolock,tcp <Shared path of the file system> /mnt/dst
  5. Install rclone on the ECS.
    wget https://downloads.rclone.org/v1.53.4/rclone-v1.53.4-linux-amd64.zip --no-check-certificate
    unzip rclone-v1.53.4-linux-amd64.zip
    chmod 0755 ./rclone-*/rclone
    cp ./rclone-*/rclone /usr/bin/
    rm -rf ./rclone-*
  6. Synchronize data to the SFS Turbo file system.
    rclone copy /mnt/src /mnt/dst -P --transfers 32 --checkers 64 --links --create-empty-src-dirs
    The parameters are described as follows. Set transfers and checkers based on the system specifications.
    • --transfers: number of files that can be transferred concurrently
    • --checkers: number of local files that can be scanned concurrently
    • -P: data copy progress
    • --links: replicates the soft links from the source. They are saved as soft links in the destination.
      --copy-links: replicates the content of files to which the soft links point. They are saved as files rather than soft links in the destination.
    • --create-empty-src-dirs: replicates the empty directories from the source to the destination.
    After data synchronization is complete, go to the SFS Turbo file system to check whether data is migrated.
To migrate data from an on-cloud NAS to your SFS Turbo file system, ensure that the NAS and SFS Turbo file system are in the same VPC, or you have established the network using Cloud Connect.
For details about how to configure Cloud Connect, see Cloud Connect User Guide.
