Managing General-Purpose File System Tags
You can add tags to existing general-purpose file systems. You can also add tags when creating general-purpose file systems. For details, see Creating a General-Purpose File System.
Tags are used to identify and classify general-purpose file systems. For more information about tags, see Tag Management Service Documentation.
- A tag is composed of a key-value pair.
- A tag key can contain a maximum of 128 characters. It can contain letters, digits, and spaces representable in UTF-8 and special characters (_.:=+-@). It cannot start or end with a space and cannot be left empty. Tag keys starting with _sys_ are system tags, and you cannot start a tag key with _sys_.
- A tag value can contain a maximum of 255 characters. It can contain letters, digits, and spaces representable in UTF-8 and special characters (_.:=+-@) and can be left empty. It cannot start or end with a space.
- You can add a maximum of 20 tags to a general-purpose file system.
- Tag keys of the same general-purpose file system must be unique.
Tags help you to identify your cloud resources. When you have many cloud resources of the same type, you can use tags to classify them by dimension (for example, by purpose, owner, or environment) for usage or cost analysis.
In SFS, you can use tags to identify and classify file systems.
If you add tags to a file system, the bills generated for this file system will contain these tags. You can activate the tags and classify bills by tag for cost analysis.
- Log in to the SFS console.
- Choose General-Purpose File System > File Systems. In the file system list, find the general-purpose file system you want to add tags and click its name to go to its details page.
- In the navigation pane on the left, choose Tag Management, as shown in Figure 1.
- Click Edit Tag to open the Edit Tag page. Figure 2 Edit Tag
- Add tag keys and values and click OK.
- Tag key: This parameter is mandatory.
- Tag value: This parameter is optional.
- Return to the tag list. You can see the tags you have just added. Edit or delete the tags if needed.
