Help Center/ Scalable File Service/ User Guide/ Other Operations/ Data Migration/ Using Direct Connect to Migrate Data
Updated on 2025-03-21 GMT+08:00
Context
You can migrate data from a local NAS to SFS Turbo using Direct Connect.
In this solution, a Linux ECS is created to connect the local NAS and SFS Turbo, and data is migrated to the cloud using an ECS.
You can also refer to this solution to migrate data from an on-cloud NAS to SFS Turbo. For details, see Migrating Data from On-cloud NAS to SFS.
Limitations and Constraints
  • Only Linux ECSs can be used to migrate data.
  • The UID and GID of your file will no longer be consistent after data migration.
  • The file access modes will no longer be consistent after data migration.
  • Incremental migration is supported, so that only changed data is migrated.
  • You have enabled and configured Direct Connect. For details, see Direct Connect User Guide.
  • You have created a Linux ECS.
  • You have created an SFS Turbo file system and have obtained the mount point of the file system.
  • You have obtained the mount point of the local NAS.
  1. Log in to the ECS console.
  2. Log in to the created Linux ECS to access the local NAS and SFS Turbo file system.
  3. Mount the local NAS to the ECS.
    Replace <Shared path of the local NAS> with the actual NAS address, for example, 192.168.0.0:/. Replace /mnt/src with the actual source path.
    mount -t nfs -o vers=3,timeo=600,noresvport,nolock <Shared path of the local NAS> /mnt/src
  4. Mount the SFS Turbo file system to the ECS.
    Replace <Shared path of the SFS Turbo file system> with the actual SFS Turbo file system address, for example, 192.168.0.0:/. Replace /mnt/dst with the actual destination path.
    mount -t nfs -o vers=3,timeo=600,noresvport,nolock <Shared path of the SFS Turbo file system> /mnt/dst
  5. Install rclone on the ECS.
    wget https://downloads.rclone.org/v1.53.4/rclone-v1.53.4-linux-amd64.zip --no-check-certificate
    unzip rclone-v1.53.4-linux-amd64.zip
    chmod 0755 ./rclone-*/rclone
    cp ./rclone-*/rclone /usr/bin/
    rm -rf ./rclone-*
  6. Synchronize data.
    rclone copy /mnt/src /mnt/dst -P --transfers 32 --checkers 64 --links --create-empty-src-dirs
    Set transfers and checkers based on the system specifications. The parameters are described as follows:
    • --transfers: number of files that can be transferred concurrently
    • --checkers: number of local files that can be scanned concurrently
    • -P: data copy progress
    • --links: replicates the soft links from the source. They are saved as soft links in the destination.
      --copy-links: replicates the content of files to which the soft links point. They are saved as files rather than soft links in the destination.
    • --create-empty-src-dirs: replicates the empty directories from the source to the destination.
    After data synchronization is complete, go to the target file system to check whether data is migrated.
To migrate data from an on-cloud NAS to your SFS Turbo file system, ensure that the NAS and file system are in the same VPC, or you can use Cloud Connect to migrate data.
For details about how to configure Cloud Connect, see Cloud Connect User Guide.
