Help Center/ ServiceStage/ User Guide/ Release Management/ New Release Management/ Managing Region Release Tasks/ Configuring a Triggering Policy of a Region Release Task
Updated on 2025-09-28 GMT+08:00
Set a triggering policy for a region release task so that the release task can be started when the configured triggering policy is met.
The region release task has been created. For details, see Creating a Region Release Task.
  1. Log in to ServiceStage.
  2. Choose Release Management.
    • If the Release Management page of the new version is displayed by default, go to 4.
      Overview describes release management of the new version.
    • If the Release Management page of the old version is displayed by default, go to 3.
      Overview describes release management of the old version.
  3. Click Try new edition now or Try New Edition to switch to the Release Management page of the new version.
    The data of the old and new versions are isolated. Switching them will not cause release task data loss.
  4. Choose Region Release Tasks.
  5. Use either of the following methods to go to the page for configuring the triggering policy:
    • Directly access: Click More > Set Trigger Policy in the Operation column of the target release task.
    • Access after viewing details: Click the target release task. After Viewing Region Release Task Details, choose ... > Configure Trigger in the upper right corner.
  6. Select the task for which you want to set a triggering policy and click Next.
  7. Set the triggering policy by referring to the following table.
    Trigger Type
    Manual
    Manually start the release task.
    1. Set Type to Manual.
    2. Click OK.
      After the manual triggering policy is set, you can manually start the release task by referring to Releasing a Region Release Task.
    Scheduled
    Triggers a pipeline at a scheduled time.
    1. Set Type to Scheduled.
    2. Disable Periodic Triggering.
    3. Set Triggered.
    4. Click OK.
    Triggers the pipeline repeatedly.
    2. Enable Periodic Triggering.
    3. Set Schedule, Triggered, Effective Time, and Days.
    4. Click OK.
  8. Click OK.
