Help Center/ ServiceStage/ User Guide/ Release Management/ New Release Management/ Managing Region Release Tasks/ Cloning a Region Release Task Created Using Manual Configurations
Updated on 2025-09-28 GMT+08:00
This section describes how to clone a region release task created by Creating a Region Release Task Using Manual Configurations.
The region release task has been created using manual configurations. For details, see Creating a Region Release Task Using Manual Configurations.
  1. Log in to ServiceStage.
  2. Choose Release Management.
    • If the Release Management page of the new version is displayed by default, go to 4.
      Overview describes release management of the new version.
    • If the Release Management page of the old version is displayed by default, go to 3.
      Overview describes release management of the old version.
  3. Click Try new edition now or Try New Edition to switch to the Release Management page of the new version.
    The data of the old and new versions are isolated. Switching them will not cause release task data loss.
  4. Choose Region Release Tasks.
  5. Use either of the following methods to go to the page for cloning a release task:
    • Directly clone: Click More > Clone in the Operation column of the target release task.
    • Clone after viewing details: Click the target release task. After Viewing Region Release Task Details, choose ... > Clone in the upper right corner.
  6. Edit the release task. For details, see 6 to 11 in Editing a Region Release Task Created Using Manual Configurations.
  7. Perform subsequent operations based on whether to release the release task.
    • If yes, click Save and Execute, select the task to be executed, and click Execute.
      If a checkpoint task is set in the release task, approve the task based on the checkpoint task type by referring to the following table.
      Checkpoint Task Type
      Approval Procedure
      Manual Approval
      1. Click the release task to be executed. The Release Process View page is displayed.
      2. Move the cursor to the card of the manual approval task to be approved.
      3. Click Approve. The Manual Approval dialog box is displayed.
      4. Enter Comments to determine whether to pass the approval.
        • Click Reject to terminate the release task. The release task fails to be released.
        • Click Agree to continue the release.
      Manual Trigger
      2. Move the cursor to the card of the manual triggering task to be approved.
      3. Click Approve. The Manual Trigger dialog box is displayed.
      4. Determine whether to pass the approval.
      • On the Release Process View page, you can view the execution status of the release process and wait until the release task is complete.
      • After the release task is saved, its Release Status is Initialized. For details about how to check the release task status, see Viewing Region Release Task Details.
      • After the release task is saved, you can manage the release task by referring to Managing Region Release Tasks.
    • If no, click Save.
