Updated on 2025-08-12 GMT+08:00
Retrying a Region Release Task
Retry a failed region release task. The release process continues from the failed task.
The region release task is in the Release failed state. For details about how to check the region release task status, see Viewing Region Release Task Details.
  1. Log in to ServiceStage.
  2. Choose Release Management.
    • If the Release Management page of the new version is displayed by default, go to 4.
      Overview describes release management of the new version.
    • If the Release Management page of the old version is displayed by default, go to 3.
      Overview describes release management of the old version.
  3. Click Try new edition now or Try New Edition to switch to the Release Management page of the new version.
    The data of the old and new versions are isolated. Switching them will not cause release task data loss.
  4. Choose Region Release Tasks.
  5. Click the release task to be retried. The Release Process View page is displayed.
  6. Click Retry in the upper right corner.
    • If a checkpoint task is set in the release task, approve the task based on the checkpoint task type by referring to the following table.
      Checkpoint Task Type
      Approval Procedure
      Manual Approval
      1. Click the release task to be executed. The Release Process View page is displayed.
      2. Move the cursor to the card of the manual approval task to be approved.
      3. Click Approve. The Manual Approval dialog box is displayed.
      4. Enter Comments to determine whether to pass the approval.
        • Click Reject to terminate the release task. The release task fails to be released.
        • Click Agree to continue the release.
      Manual Trigger
      2. Move the cursor to the card of the manual triggering task to be approved.
      3. Click Approve. The Manual Trigger dialog box is displayed.
      4. Determine whether to pass the approval.
    • Wait until the release status changes from Running to Successful, which indicates that the release task is successfully released.
