Help Center/ ServiceStage/ User Guide/ Component Management/ Managing VM-Deployed Component Configurations/ Configuring Application Performance Management of a VM-Deployed Component
Updated on 2025-09-26 GMT+08:00
Performance management helps you quickly locate problems and identify performance bottlenecks to improve your experience. Selecting Java probe will start APM and install Java probes on the nodes deployed with APM, which consumes a small amount of resources. Java probes use the bytecode enhancement technology to trace Java application calls and generate topology and call chain data.
Precautions
  • This function can be enabled only when APM of the corresponding version is deployed and enabled in the environment. For details, see Usage Restrictions.
  • JDK versions other than OpenJDK 11 and OpenJDK 17 are supported.
  • The Tomcat technology stack supports Tomcat 8, Tomcat 9, and custom Tomcat.
  • Performance management can be configured for Java applications whose technology stack type is Java or Tomcat.
  1. Choose Advanced Settings > Performance Management.
  2. Select Java probe and set probe parameters based on your probe type by referring to the following table.
    Probe Type
    APM 2.0
    1. Set Application.
      • Select the application that has the same name as the application where the application component is located from the drop-down list.
      • If the application does not exist, click Create Application to create it. After the application is created, Log in to APM and view the new application in the application list.
    2. Set Probe Version.
      The value is fixed to latest, indicating that the latest version is used.
    3. Set Access Key.
      The access key is automatically obtained. If the access key cannot be automatically obtained, manually enter it.
