Help Center/
ServiceStage/
User Guide/
Configuration Management/
Managing Configuration Files/
Comparing Configuration Files
Updated on 2025-09-26 GMT+08:00
This section describes how to compare the differences between the current and historical versions of a configuration file.
Either of the following operations has been performed on the configuration files to be compared:
- Log in to ServiceStage.
- Choose Configuration Management > List.
- Use either of the following methods to open the Historical Version dialog box:
- Click View History in the Operation column of the target configuration file.
- Click the target configuration file and click View History.
- Move the cursor to a historical version.
- Use either of the following methods to open the Compare Version dialog box and compare the configuration files of the historical and current versions.
- Directly compare: Click Compare.
- Compare after viewing the historical version configuration: Click View to view the configuration details of the historical version, and click Comparison with the Current Version.
Parent topic: Managing Configuration Files
