Updated on 2025-07-10 GMT+08:00
Exporting a Configuration File
This section describes how to export the current version of a configuration file so that you can view, edit, and share the configuration file locally.
The configuration file to be exported is available.
  1. Log in to ServiceStage.
  2. Choose Configuration Management > List.
  3. Select a configuration file export method by referring to the following table.
    Export Method
    Result
    Batch export
    1. Select the configuration files.
    2. Click Export.
    • The exported configuration file is named {Timestamp}.zip, for example, 1743642593371.zip. The timestamp (for example, 1743642593371) is the time when you click Export.
    • The name of the level-1 file directory in the package is the name of the enterprise project to which the configuration group of the configuration file to be exported belongs.
    • The name of the level-2 file directory is the name of the configuration group to which the configuration file to be exported belongs.
    • The configuration file in the level-2 directory is the configuration file to be exported.
    Single export
    1. Click a configuration file.
    2. In the File Content area, click Download File.
    • The exported configuration file is named {Timestamp}.zip, for example, 1743642593371.zip. The timestamp (for example, 1743642593371) is the time when you click Download File.
    • The name of the file directory in the package is the name of the configuration group to which the configuration file to be exported belongs.
    • The configuration file in the directory is the configuration file to be exported.
