VM Agent Overview
Updated on 2024-12-16 GMT+08:00
To deploy a component to a VM, you need to install the VM agent. After the host node is managed, the management node can communicate with the host node.
VM Agent Status Description
For details about the VM agent status and description, see Table 1.
Table 1 VM agent status description
Agent Status
Agent uninstalled
The VM agent is not installed on the ECS node. You need to install the VM agent.
Online
The VM agent has been installed on the ECS node and is running properly.
Agent offline
The VM agent has been installed on the ECS node, but is offline and cannot work properly.
For details about how to handle agent offline, see What Should I Do If the VM Agent Is Offline?
Upgrading
The VM agent has been installed on the ECS node and is being upgraded.
Upgrade failed
The VM agent has been installed on the ECS node and fails to be upgraded.
Agent restarting
The VM agent has been installed on the ECS node and is restarting.
Supported OSs and Versions
The VM agent supports multiple OSs. You need to create an image by referring to Table 2, use the created image to create an ECS, and install the VM agent.
Table 2 OSs and versions supported by the VM agent
OS
Version
EulerOS
  • 2.2 64bit
  • 2.3 64bit
  • 2.5 64bit
  • 2.8 64bit
  • For Linux x86_64 servers, all the listed OSs and versions are supported.
  • For Linux Arm servers, all the listed OSs and versions except CentOS 7.3 and earlier are supported.
CentOS
  • 6.5 64bit
  • 6.8 64bit
  • 6.9 64bit
  • 6.10 64bit
  • 7.2 64bit
  • 7.3 64bit
  • 7.4 64bit
  • 7.5 64bit
  • 7.6 64bit
  • 7.7 64bit
  • 7.8 64bit
  • 7.9 64bit
Fedora
  • 29 64bit
  • 30 64bit
openEuler
20.03 64bit
