Searching for Running Logs
Updated on 2024-12-16 GMT+08:00
After associating a component with an LTS log group, you can set a keyword and time range to search for logs.
The component has been associated with a log group. For details, see Associating an LTS Log Group.
  1. Log in to ServiceStage.
  2. Use either of the following methods to go to the Logs page.
    • On the Application Management page, click the application to which the component belongs, click the target component in Component List, and choose O&M Configurations > Logs in the left navigation pane.
    • On the Component Management page, click the target component and choose O&M Configurations > Logs in the left navigation pane.
  3. On the Running Logs(LTS) page, select a log stream from the drop-down list.
  4. Select a time range in the upper right corner.
    • From now: queries log data generated in a time range that ends with the current time, such as the previous 1, 5, or 15 minutes. For example, if the current time is 19:20:31 and 1 hour is selected as the relative time from now, the charts on the dashboard display the log data that is generated from 18:20:31 to 19:20:31.
    • From last: queries log data generated in a time range that ends with the current time, such as the previous 1 or 15 minutes. For example, if the current time is 19:20:31 and 1 hour is selected as the relative time from last, the charts on the dashboard display the log data that is generated from 18:00:00 to 19:00:00.
    • Specified: queries log data that is generated in a specified time range.
  5. On the log details page, you can search for logs using the following methods:
    • Enter a keyword in the search box and click Search, or select a historical record, index field, or keyword from the displayed drop-down list.
    • On the Raw Logs tab, hover the cursor over a field in the log content, click it, and choose Copy, Add To Search, or Exclude from Search from the displayed menu.
    • In the displayed drop-down list, press the up and down arrows on the keyboard to select a keyword or search syntax, press Tab or Enter, and click Search.
