On this page
Show all
Managing Component AOM Logs
Updated on 2024-12-16 GMT+08:00
ServiceStage component logs are connected to AOM by default. You can view, search for, and export logs to locate and rectify faults that occur during component running.
  1. Log in to ServiceStage.
  2. Use either of the following methods to go to the Logs page.
    • On the Application Management page, click the application to which the component belongs, click the target component in Component List, and choose O&M Configurations > Logs in the left navigation pane.
    • On the Component Management page, click the target component and choose O&M Configurations > Logs in the left navigation pane.
    If the component is created by Creating a Component by Importing a CCE Workload and is not enabled:
    1. In the displayed dialog box, click OK.
    2. On the Enable Component page, click Enable and wait until the component is restarted.
  3. On the Running Logs(AOM) page, manage component running logs by referring to the following table.
    Operation
    View Logs
    1. Select the instance whose logs you want to view.
    2. Select the log file you want to view.
    3. Select the time range of the logs you want to view.
      If you select Custom, the time range cannot exceed 30 days.
    4. Enter keywords in the search box and click to view details about the specified logs.
    Export Logs
    1. Click Last Records.
    2. Select the number of log records to be exported.
    3. Open the log.txt file exported locally and view the exported log records.
    View AOM Logs
    Click View AOM Logs. You can view the component run logs on the AOM console.
    For details, see Viewing Log Files.
    If you cannot view logs on the ServiceStage Logs page, see Why Can't I View ServiceStage Logs?
