- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Before You Start
- Permissions Management
Environment Management
- Environment Overview
- Creating an Environment
- Managing CCE Resources
- Managing Basic Resources
- Removing Managed Basic Resources
- Managing VM Agents
- Modifying an Environment
- Deleting an Environment
- Application Management
Component Management
- Component Overview
- Creating and Deploying a Component
- Viewing Component Details
- Managing Component Labels
- Changing the Component Description
- Managing Component Instances
- Upgrading a Single Component
- Upgrading Components in Batches
- Cloning Components in Batches
- Synchronizing Component Configurations in Batches
- Rolling Back a Component
- Redeploying a Component
- Configuring the Component Access Mode
- Changing the Component Access Domain Name
- Configuring a Scaling Policy of a Component Instance
- Component O&M
- Viewing the Component Running Environment
- Starting and Stopping a Component Instance
- Manually Synchronizing the Component Status
- Managing Cloud Service Settings of a Container-Deployed Component
- Managing Container Settings of a Container-Deployed Component
- Managing Application Settings of a Container-Deployed Component
- Managing Advanced Settings of a Container-Deployed Component
- Managing VM-Deployed Component Configurations
- Deleting a Component
- Configuration Management
- Release Management (OBT)
- Tech Stack Management
- Deployment Source Management
- Continuous Delivery
Microservice Engine
- Cloud Service Engine Overview
- Creating a Microservice Engine
Managing Microservice Engines
- Viewing Microservice Engine Information
- Obtaining the Service Center Address of a Microservice Engine
- Obtaining the Configuration Center Address of a Microservice Engine
- Viewing the Instance Quota of a Microservice Engine
- Viewing the Configuration Item Quota of a Microservice Engine
- Configuring Backup and Restoration of a Microservice Engine
- Managing Public Network Access for a Microservice Engine
- Viewing Microservice Engine Operation Logs
- Upgrading a Microservice Engine Version
- Deleting a Microservice Engine
- Managing Security Authentication for a Microservice Engine
- Using Microservice Engines
- Key Operations Recorded by CTS
- Viewing Monitoring Metrics and Alarms
Developer Guide
Microservice Developer Guide
- Overview
- Developing Microservice Applications
- Preparing the Environment
- Connecting Microservice Applications
- Deploying Microservice Applications
- Using Microservice Engine Functions
- Appendix
Best Practices
- ServiceStage Best Practices
- Hosting and Managing a Weather Forecast Microservice Application on ServiceStage
- Enabling Security Authentication for an Exclusive ServiceComb Engine
- Connecting ServiceComb Engine Dashboard Data to AOM through ServiceStage
- Migrating the Registered Microservice Engine Using ServiceStage Without Code Modification
- Hosting a Spring Boot Application on ServiceStage
- Using GitLab to Interconnect with Jenkins to Automatically Build and Upgrade Components Deployed on ServiceStage
- Using ServiceStage to Migrate Components Across AZs and Upgrade Components in Sequence Based on Release Management
API Reference
- Before You Start
- API Overview
- Calling APIs
Application Management V3 APIs
Environment
- Obtaining All Environments
- Deleting an Environment Based on the Environment ID
- Modifying an Environment Based on the Environment ID
- Obtaining Environment Details Based on the Environment ID
- Modifying an Environment Resource Based on the Environment ID
- Enabling an Environment Resource Based on the Environment ID
- Querying a Managed Resource Based on the Environment ID
- Querying a Created Resource Based on the Environment ID
- Adding an Environment Resource Based on the Environment ID
- Updating an Environment Resource Based on the Environment ID
- Deleting an Environment Resource Based on the Environment ID
- Querying Resource Enabling Records Based on the Environment ID
- Querying the Details of a Resource Enabling Record Based on the Environment ID
- Querying the Events of a Resource Enabling Record Based on the Environment ID
Application
- Creating an Application
- Obtaining All Applications
- Modifying Application Information Based on the Application ID
- Deleting an Application Based on the Application ID
- Obtaining Application Details Based on the Application ID
- Obtaining Application Configurations Based on the Application ID
- Modifying Application Configurations Based on the Application ID
- Deleting Application Configurations Based on the Application ID
Component
- Creating an Application Component
- Importing a CCE Workload to an Application to Create a Component
- Obtaining All Components of an Application
- Modifying Component Information Based on the Component ID
- Deleting a Component Based on the Component ID
- Obtaining Component Information Based on the Component ID
- Delivering a Component Task Based on the Component ID
- Obtaining Records Based on the Component ID
- Refreshing Component Information Based on the Component ID
- Obtaining Component Configuration Information
Technology Stack
- Querying a Runtime System Stack
- Querying a Built-in Image
- Creating a Technology Stack
- Querying a Technology Stack Based on the Technology Stack ID
- Modifying a Technology Stack Based on the Technology Stack ID
- Deleting a Technology Stack Based on the Technology Stack ID
- Releasing or Canceling the Release of a Technology Stack
- Creating a Configuration Group
- Obtaining a Configuration Group
- Creating a Configuration File
- Importing a Configuration File
- Obtaining Configuration File Information
- Obtaining Configuration File Information Based on the Configuration File ID
- Deleting a Configuration File Based on the Configuration File ID
- Modifying a Configuration File Based on the Configuration File ID
- Obtaining the Configuration File Record Based on the Configuration File ID
- Obtaining the Configuration File Record Information Based on the Record ID
- Deleting a Configuration File Record Based on the Record ID
- Obtaining Configuration Group Details Based on the Group ID
- Deleting a Configuration Group Based on the Group ID
- Deployment Job
- Add-on Management
Environment
Git Repository Access APIs
- Obtaining a Git Repository Authorization List
- Obtaining an Authorization Redirection URL
- Creating OAuth Authorization
- Creating Private Token Authorization
- Creating Password Authorization
- Deleting Repository Authorization
- Obtaining a Repository Namespace
- Obtaining Repository Information Based on the Clone URL
- Obtaining All Projects in a Namespace
- Creating a Software Repository Project
- Obtaining a Project Branch
- Obtaining a Project Tag
- Creating a Project Tag
- Deleting a Project Tag
- Obtaining Project Commits
- Obtaining a Project Hook
- Creating a Project Hook
- Deleting a Project Hook
- Obtaining a Repository File Directory
- Obtaining Repository File Contents
- Creating a Repository File
- Modifying Repository File Contents
- Deleting a Repository File
CSE APIs
- API Calling
- Dynamic Configuration
Engine Management
- Querying Flavors Supported by an Exclusive Microservice Engine
- Querying the Exclusive Microservice Engine List
- Creating an Exclusive Microservice Engine
- Querying Details About an Exclusive Microservice Engine
- Deleting an Exclusive Microservice Engine
- Querying Details About an Exclusive Microservice Engine Job
ServiceComb APIs
- API Calling
- Authentication
Microservice
- Querying Information About a Microservice
- Deleting Definition Information About a Microservice
- Querying Information About All Microservices
- Creating Static Information for a Microservice
- Deleting Static Information About Microservices in Batches
- Modifying Extended Attributes of a Microservice
- Querying the Unique Service or Schema ID of a Microservice
- Schema
Microservice Instance
- Registering a Microservice Instance
- Querying a Microservice Instance Based on service_id
- Deregistering a Microservice Instance
- Querying Details About a Microservice Instance
- Modifying the Extended Information About a Microservice Instance
- Modifying Status of a Microservice Instance
- Sending Heartbeat Information
- Querying a Microservice Instance by Filter Criteria
- Querying Microservice Instances in Batches
- Dependency
- Examples
- Data Structure
- Appendix
Historical APIs
Application Management V2 APIs
- Meta
- Environment
Application
- Component
- Instance
- Deployment Jobs
- Build APIs
- Querying Configurations
- Creating a Dependency Between Services
- Reporting Service Metrics
- SDK Reference
- Application Development FAQs
- Environment Management
- How Do I View the Causes of Application Component Deployment Failures?
- What If an Instance Is Being Created for a Long Time?
- How Do I Solve the Dependency Problem When a Node Program Runs in Docker?
- How Do I Customize a Tomcat Context Path?
- How Do I Use a Fixed Application Component IP?
- What Should I Do If an ECS Error Occurs When I Create and Deploy a Component on a VM?
- What Should I Do If I Cannot Access the Port When I Create and Deploy a Component on a VM?
- Which Directories Do I Use to Write Files for VM-Deployed Application Components?
- What Should I Do If "host status is not active" Is Reported When a VM-Deployed Component Fails to Be Deleted?
- How Do I Use the ServiceStage Source Code Deployment Function?
- What Should I Do If Components Fail to Be Upgraded in ServiceStage Dark Launch?
- How Do I Mount Items to Modify the Configuration File of a Container-based Component?
- What Should I Do If the Application Name Displayed on Microservice Governance Is Different from That Displayed on ServiceStage Application Management After an Application Component Is Connected to a Microservice Engine?
Continuous Delivery
- How Does ServiceStage Manage Code on IDEA?
- How Do I Add the Build Server Address to the GitLab Server Security Group?
- How Do I Add the Build Server Address to the Maven Server Security Group?
- What Do I Do If ServiceStage Failed to Build a Job?
- How Can I Access Dependent Services Through VPC Endpoints When Building Images?
- Software Center
Infrastructure
- Are Existing Programs Affected If I Unsubscribe Servers?
- How Can I Access Dependent Services Through VPC Endpoints When Installing VM Agents?
- What Should I Do If I Don't See the VM Agent After Installing It?
- What Should I Do If the VM Agent Is Offline?
- What Should I Do If the Service Registration Fails After IPv6 Is Enabled for the Exclusive Microservice Engine with Security Authentication Enabled?
- What Should I Do If a Non-Microservice Engine Error Occurs When I Operate an Exclusive Microservice Engine?
- How Do I Switch a Cluster Used for Component Building from a Shared Cluster to a Private One?
- What Should I Do If the Access Address Fails to Be Processed During CSE Creation?
- What Do I Need to Know Before Upgrading an Exclusive Microservice Engine?
- Obtain Configurations Failed
- Application O&M
- What Are the Differences Between the Microservice and Common Application?
- How Do I Handle a Microservice Registry Failure (Java Chassis)?
- How Do I Troubleshoot Microservices Deployed on the Cloud?
- Should I Use the SDK or ServiceMesh to Build a Microservice?
- What If I Fail to Obtain a Dependency?
- What Is Service Name Duplication Check?
- Why Do I Have to Define Service Contracts?
- Why Are Microservice Development Framework and Netty Versions Unmatched?
- How Do I Package a Java or Tomcat Application?
More Documents
- Getting Started
User Guide
- Overview
Application O&M
- Maintaining Application Component Instances
- Adding Labels for Application Component Instances
- Configuring Domain Name Mappings
- Configuring Alarm Thresholds for Resource Monitoring
- Configuring a Scaling Policy of an Application Component Instance
- Configuring a Scheduling Policy of an Application Component Instance
- Configuring an Upgrade Policy of an Application Component Instance
- Configuring Custom Monitoring of an Application Component
- Configuring a Log Policy of an Application
- Configuring Health Check
- Software Center
Infrastructure
Cloud Service Engine (CSE)
- Overview
Microservice Engine Management
- Configuring Backup and Restoration of an Exclusive Microservice Engine
- Configuring Public Network Access of an Exclusive Microservice Engine
- Viewing the Access Address of a Microservice Engine
- Viewing Operation Logs of an Exclusive Microservice Engine
- Upgrading an Exclusive Microservice Engine
- Using the Microservice Dashboard
- Microservice Governance
- Configuring Microservices
- Maintaining Microservices
- Installing VM Agent on a Single VM
- How Do I Obtain an AK/SK Pair?
- What Should I Do If an Error Occurs When I Change the Name of a Project ?
- What Are the Differences Between Microservices and Common Applications?
- How Do I View the Causes for Application Component Deployment Failures?
- What Should I Do If a VM Component Fails to Be Deployed or Updated?
- What Are the Constraints on Packaging a Node.js 8 Software Package?
- What Should I Do If the Agent Fails to Be Installed?
- What Should I Do If the Agent Is Offline?
- Which Directories Do I Use to Write Files for VM-based Application Components?
- What Should I Do If "host status is not active" Is Reported When a VM-based Component Fails to Be Deleted?
- How Do I Handle Docker Application Dependency?
- What Should I Do If Docker Client Fails to Push Images?
- How Do I Obtain a Project Name?
- What Should I Do I Get an ECS Error When Deploying VM-based Components?
- What Should I Do If an ECS Error Occurs During VM-based Component Deployment?
- What Should I Do If I Cannot Access the Port During VM-based Deployment?
- What Should I Do If the Microservice Application Name Is Different from the Component Application Name?
- Why the Microservice Name Is Different from the Component Name?
- Failed to Restore Data of an Exclusive Microservice Engine
- Before You Start
- API Overview
- Calling APIs
Application Management APIs
- Meta
- Environment
Application
- Adding or Modifying Application Configurations
- Component
Instance
- Creating an Application Component Instance
- Obtaining All Instances of a Component
- Querying the Operations Performed on a Component Instance
- Modifying an Application Component Instance
- Deleting an Application Component Instance
- Querying Instance Details Based on the Instance ID
- Obtaining Component Instance Snapshots
- Job
CSE API
- API Calling
- Querying Static Information About a Microservice
- Querying Static Information About All Microservices
- Modifying Static Information About a Microservice
- Querying a Microservice Schema
- Modifying a Microservice Schema
- Querying All Providers of a Microservice
- Querying All Instances of a Microservice Based on the Service ID
- Changing the Status of a Microservice Instance
- Deleting Static Information About a Microservice
- Querying All Schema Information About a Microservice
- Data Structure
- Appendix
- Getting Started
- Overview
- Setting the Access Mode of Components
- Component O&M
- Component Instance Start and Stop
Component Advanced Setting
- Setting Component Environment Variables
- Configuring the Lifecycle of a Component
- Configuring Data Storage
- Configuring a Distributed Cache
- Configuring Relational Databases
- Configuring a Scheduling Policy of a Component Instance
- Configuring Custom Monitoring of a Component
Microservice Engine
- Viewing the Quota of Microservice Engine Instances
- Viewing the Quota of Microservice Engine Configuration Items
- Managing Security Authentication of a Microservice Engine
- Infrastructure
- Application O&M
- Before You Start
- API Overview
- Calling APIs
- Meta
- Environment
Application
- Component
Instance
- Job
CSE API
- API Calling
- Data Structure
- Appendix
- Videos
ServiceStage allows you to obtain custom metrics when components are deployed using CCE. You can use this method to report custom component running metrics.
You can configure custom monitoring of a component when configuring Advanced Settings.
Restrictions
- Currently, only Gauge metrics of Prometheus can be obtained.
- Before setting custom metric monitoring for an application component, you must understand Prometheus and provide the GET API for obtaining custom metric data in your application component so that ServiceStage can obtain custom metric data using this API.
- Choose Advanced Settings > O&M Policy.
- Configure custom monitoring by referring to the following table.
Mandatory
Report Path
URL provided by the exporter for ServiceStage to obtain custom metric data.
Example: /metrics
Yes
Report Port
Port provided by the exporter for ServiceStage to obtain custom metric data.
Example: 8080
Yes
Monitoring Metrics
Name of the custom metric provided by the exporter.
Example: ["cpu_usage","mem_usage"]
- If this parameter is not set, ServiceStage collects data of all custom metrics.
- If you set this parameter, for example, to ["cpu_usage","mem_usage"], ServiceStage collects the data of the specified cpu_usage and mem_usage metrics.
No
After the configuration and deployment are complete, you can view the monitoring metric data on the AOM console. For details, see Metric Monitoring.
