Help Center/ ServiceStage/ User Guide/ Component Management/ Viewing the Component Running Environment
Updated on 2025-09-26 GMT+08:00
After a component is successfully deployed, you can view the resources (such as CCE clusters and microservice engines) on which the component depends and the resource status and usage on the component Infrastructure page.
  1. Log in to ServiceStage.
  2. Use either of the following methods to go to the Infrastructure page.
    • On the Application Management page, click the application to which the component belongs, click the target component in Component List, and choose Infrastructure in the left navigation pane.
    • On the Component Management page, click the target component and choose Infrastructure in the left navigation pane.
  3. On the component Infrastructure page, select component running resources and view the resource status and usage.
