Help Center/ ServiceStage/ User Guide/ Component Management/ Component O&M/ Viewing Component Running Metrics
Updated on 2025-11-21 GMT+08:00
After a component is created and deployed, you can go to its Metric Monitoring Graphs page to view the statistics of component running metrics.
  • You have created and deployed a component. For details, see Creating and Deploying a Component.
  • For container-deployed components, a CCE cluster must be bound to the component deployment environment.
  1. Log in to ServiceStage.
  2. Use either of the following methods to go to the Metric Monitoring Graphs page.
    • On the Application Management page, click the application to which the component belongs, click the target component in Component List, and choose O&M Configurations > Monitoring Overview in the left navigation pane.
    • On the Component Management page, click the target component and choose O&M Configurations > Monitoring Overview in the left navigation pane.
  3. If the component is created by Creating a Component by Importing a CCE Workload and is not enabled:
    1. In the displayed dialog box, click OK.
    2. On the Enable Component page, click Enable and wait until the component is restarted.
  4. On the Metric Monitoring Graphs page, view the statistics of component running metrics in the last hour at an interval of 1 minute.
    • Click on the component running metric page for which you want to suspend statistics collection.
    • Click on the component running metric page to continue collecting statistics on the running metric.
      Figure 1 Metric graph
