Updated on 2025-07-10 GMT+08:00
Deleting an Application
You can delete an application that is no longer used.
No component is contained in the application or all components in the application have been deleted. For details, see Deleting a Component.
- Log in to ServiceStage.
- Choose Application Management.
- Use either of the following methods to delete an application:
- Directly delete: Select the target application and click Delete in the Operation column.
- Delete after viewing application details: Click the target application to go to the Component Management page. After Viewing Application Overview, click Delete in the upper right corner.
- Click OK.
Parent topic: Application Management
