Updated on 2025-09-26 GMT+08:00
Editing an Application
You can modify the application parameters as required.
You have created an application. For details, see Creating an Application.
  1. Log in to ServiceStage.
  2. Choose Application Management.
  3. Use either of the following methods to go to the application editing page:
    • Directly edit: Select the target application and click Edit in the Operation column.
    • Edit after viewing application details: On the Application Management page, click the target application to go to the Component Management page. After Viewing Application Overview, click Edit in the upper right corner.
  4. Configure the application again by referring to the following table.
    Name
    Unique application name.
    Enter 2 to 64 characters. Start with a letter and end with a letter or digit. Only use letters, digits, underscores (_), and hyphens (-).
    Enterprise Project
    Select an enterprise project.
    Enterprise projects let you manage cloud resources and users by project.
    It is available after you enable the enterprise project function.
    • Click the drop-down list to select an existing enterprise project.
    • Click Create Enterprise Project to create an enterprise project and select it. For details, see Creating an Enterprise Project.
    Tags
    Tags are used to identify cloud resources. When you have multiple cloud resources of the same type, you can use tags to classify them based on usage, owner, or environment.
    If your organization has configured tag policies for ServiceStage, add tags to trackers based on the policies. If a tag does not comply with the tag policies, application editing may fail. Contact your administrator to learn more about tag policies.
    Each application can have a maximum of 20 tags.
    • Add a tag: Enter the key and value of the tag, and click OK.
      • The key contains 1 to 63 characters. Start and end with a letter or digit. Only use digits, letters, underscores (_), hyphens (-), and periods (.).
      • The value contains 0 to 63 characters. Start and end with a letter or digit. Only use digits, letters, underscores (_), hyphens (-), and periods (.).
      If you want to use the same tag to identify multiple resources, that is, all resources can select the same tag from the drop-down list, you are advised to create a predefined tag in TMS by referring to Creating Predefined Tags.
    • Delete a tag: Click next to the tag to be deleted.
    Application description. Enter up to 128 characters.
  5. Click OK.
