Creating an Application
Create an application before Creating and Deploying a Component.
ServiceStage allows a single user to create a maximum of 7500 applications under the same project.
Video Tutorial
- Log in to ServiceStage.
- Choose Application Management > Create Application and configure the application. Parameters marked with an asterisk (*) are mandatory.
*Name
Unique application name.
Enter 2 to 64 characters. Start with a letter and end with a letter or digit. Only use letters, digits, underscores (_), and hyphens (-).
*Enterprise Project
Select an enterprise project.
Enterprise projects let you manage cloud resources and users by project.
It is available after you enable the enterprise project function.
- Click the drop-down list to select an existing enterprise project.
- Click Create Enterprise Project to create an enterprise project and select it. For details, see Creating an Enterprise Project
Tags
Tags are used to identify cloud resources. When you have multiple cloud resources of the same type, you can use tags to classify them based on usage, owner, or environment.
If your organization has configured tag policies for ServiceStage, add tags to trackers based on the policies. If a tag does not comply with the tag policies, application creation may fail. Contact your administrator to learn more about tag policies.
Each application can have a maximum of 20 tags.
- Enter the key and value of the tag.
- The key contains 1 to 63 characters. Start and end with a letter or digit. Only use digits, letters, underscores (_), hyphens (-), and periods (.).
- The value contains 0 to 63 characters. Start and end with a letter or digit. Only use digits, letters, underscores (_), hyphens (-), and periods (.).
If you want to use the same tag to identify multiple resources, that is, all resources can select the same tag from the drop-down list, you are advised to create a predefined tag in TMS by referring to Creating Predefined Tags.
- Click OK.
Application description. Enter up to 128 characters.
- Click OK.
The created application is displayed in the application list.
