Editing an Environment
Modify the name, enterprise project, and description of an environment.
You have created an environment. For details, see Creating an Environment.
- Log in to ServiceStage.
- Choose Environment Management. The Environment Management page is displayed.
- Use either of the following methods to go to the Edit Environment page:
- Directly edit: Select the target environment and click Edit in the Operation column.
- Edit after viewing environment details: Click the target environment. On the displayed Overview page, click Edit.
- Edit the environment information by referring to the following table.
Environment
Environment name, which must be unique in the same enterprise project.
Enter 2 to 64 case-sensitive characters. Start with a letter and end with a letter or digit. Only use letters, digits, underscores (_), and hyphens (-).
Enterprise Project
Enterprise projects let you manage cloud resources and users by project.
It is available after you enable the enterprise project function.
- Click the drop-down list to select an existing enterprise project.
- Click Create Enterprise Project to create an enterprise project and select it. For details, see Creating an Enterprise Project
Environment Tag
Tags are used to identify cloud resources. When you have multiple cloud resources of the same type, you can use tags to classify them based on usage, owner, or environment.
If your organization has configured tag policies for ServiceStage, add tags to trackers based on the policies. If a tag does not comply with the tag policies, environment editing may fail. Contact your administrator to learn more about tag policies.
Each environment can have a maximum of 20 tags.
- Delete a tag
- Add a tag
- Click Add Tag. The Add Tag dialog box is displayed.
- Click Add Tag.
- Enter the key and value of the tag.
The key contains 1 to 36 characters, including digits, letters, underscores (_), or hyphens (-).
The value contains 1 to 43 characters, including digits, letters, underscores (_), periods (.), or hyphens (-).
If you want to use the same tag to identify multiple resources, that is, all resources can select the same tag from the drop-down list, you are advised to create a predefined tag in TMS by referring to Creating Predefined Tags.
- Click OK.
Environment description. Enter up to 128 characters.
- Click Save.
