Updated on 2025-09-26 GMT+08:00
Removing a Basic Resource
You can remove basic resources managed in the environment that are no longer used.
After the basic resources managed in an environment are removed, they cannot be used when this environment is used to deploy components.
Removing a resource will not delete the resource instance. Log in to the resource console and delete the resource.
The resources to be removed have been managed in the environment. For details, see Managing Basic Resources.
  1. Log in to ServiceStage.
  2. Choose Environment Management. The Environment Management page is displayed.
  3. Click the target environment. The Overview page is displayed.
  4. Choose the resource from Compute, Networking, or Middleware.
  5. In the managed resource list, perform the following operations:
    • To remove resources in batches, select the target resources and click Remove Resource.
    • To remove a single resource, click Remove in the Operation column of the target resource.
    The ServiceComb engines managed in the HA environment of the Kubernetes type can only be removed one by one.
    For details about how to remove cluster resources bound in the Kubernetes or VM + Kubernetes environments, see Unbinding a Cluster.
