Help Center/ ServiceStage/ User Guide/ Using IAM to Grant Access to ServiceStage/ Granting Permissions to ServiceStage-Dependent Services
Updated on 2025-08-05 GMT+08:00
Granting Cluster Namespace Permissions
You can grant only common operation permissions on cluster resources to the ServiceStage user group using IAM, excluding the namespace permissions of the clusters with Kubernetes RBAC authentication enabled. Therefore, grant the namespace permissions to the clusters separately.
For details, see Namespace Permissions.
Granting CTS Permissions
After the permissions are granted for ServiceStage using IAM, they do not take effect for the CTS service on which ServiceStage depends. Therefore, grant the CTS permissions separately.
For details, see Permissions Management.
