Conditional Functions
The following table lists the conditional functions supported by SecMaster SQL syntax.
| Function | Function Description |
| CASE value WHEN value1_1 [, value1_2]* THEN RESULT1 (WHEN value2_1 [, value2_2 ]* THEN result_2)* (ELSE result_z) END | Returns resultX when the first value in (valueX_1, valueX_2, ...) is included. If there is no matching value, returns result_z if provided, otherwise returns NULL. |
| CASE WHEN condition1 THEN result1 (WHEN condition2 THEN result2)* (ELSE result_z) END | Returns resultX when the first condition X is met. If no conditions are met, returns result_z if provided, otherwise returns NULL. |
| IF(condition, true_value, false_value) | Returns true_value if the condition is met, otherwise returns false_value. For example, IF(5 > 3, 5, 3) returns 5. |
