Aggregate Functions
The following table lists the aggregate functions supported by SecMaster SQL syntax.
Function |
Function Description |
COUNT([ ALL ] expression | DISTINCT expression1 [, expression2]*) |
By default or with the keyword ALL, returns the number of input rows where the expression is not NULL. Using DISTINCT calculates the count after removing duplicates. |
COUNT(*) | COUNT(1) |
Returns the number of input rows. |
AVG([ ALL | DISTINCT ] expression) |
By default or with the keyword ALL, returns the average value (arithmetic mean) of the expression across all input rows. Using DISTINCT calculates the count after removing duplicates. |
SUM([ ALL | DISTINCT ] expression) |
By default or with the keyword ALL, returns the sum of the expression across all input rows. Using DISTINCT calculates the count after removing duplicates. |
MAX([ ALL | DISTINCT ] expression) |
By default or with the keyword ALL, returns the maximum value of the expression across all input rows. Using DISTINCT calculates the count after removing duplicates. |
MIN([ ALL | DISTINCT ] expression ) |
ROW_NUMBER() |
Assigns a unique sequence number to each row within the window partition, starting from 1. (for example, 1, 2, 3, 4, and 5) |
FIRST_VALUE(expression) |
Returns the first value in a set of ordered values. |
LAST_VALUE(expression) |
Returns the last value in a set of ordered values. |
LISTAGG(expression [, separator]) |
Concatenates the values of string expressions and places a separator value between them. The separator is not added at the end of string. The default value of separator is a comma (,). |
