Empty WAF Policy Deletion (WAF clear Non-domain Policy)
Playbook Overview
The WAF clear Non-domain Policy playbook matches the WAF clear Non-domain Policy workflow. The playbook queries WAF protection policies and deletes empty protection policies to release resources at 09:00 every Monday. An empty WAF protection policy has only a policy name but does not have any domain name.
You need to manually enable this playbook for it to take effect.
- SecMaster has obtained the WAF fullAccess permission.
Table 1 Permission description Permission
Principal
WAF fullAccess
Administrator permissions for Web Application Firewall (WAF).
SecMaster_Agency
Perform the following steps to check whether SecMaster has obtained the WAF fullAccess permission: If the permission is not allocated, allocate it to SecMaster by referring to Authorizing SecMaster.
- Log in to the SecMaster console as an administrator.
- Click
in the upper left corner of the page and choose Management & Governance > Identity and Access Management. - In the navigation pane on the left, choose Agencies. On the Agencies page, click SecMaster_Agency and then click the Permissions tab to view all authorization records of SecMaster_Agency.
Figure 1 Viewing agency authorization records
Notes and Constraints
- Your SecMaster professional edition is available.
Step 1: Enable the WAF Clear Non-domain Policy Playbook
- Log in to the SecMaster console.
- In the navigation pane on the left, choose Workspaces > Management. In the workspace list, click the name of the target workspace. Figure 2 Workspace management page
- In the navigation pane on the left, choose Security Orchestration > Playbooks. Figure 3 Accessing the Playbooks tab
- On the Playbooks page, search for the WAF clear Non-domain Policy playbook and click Enable in the Operation column of the WAF clear Non-domain Policy playbook.
- In the dialog box displayed, select the initial playbook version v1 and click OK. If the Playbook Status of the WAF clear Non-domain Policy playbook changes to Enabled, the playbook has been enabled successfully.
Step 2: Approve the Deletion of the Empty WAF Policy
- In the navigation pane on the left of the target SecMaster workspace, choose .
- On the displayed page, click the To-Dos tab. In the Operation column of the target to-do task, click Review. The approval method varies depending on the service type.
- Playbook release: The Playbook Release page is displayed on the right. Enter review comments and approve the playbook as prompted.
- Process release: The Process Release page is displayed on the right. Enter the review comments and approve the application as prompted.
- Playbook-node review: The Playbook-Node Review page is displayed on the right. You can choose either Continue or Terminate.
- In the navigation pane on the left, choose , click the Completed tab, and check completed tasks.
Implementation Effect
The WAF clear Non-domain Policy playbook checks WAF protection policies at 09:00 every Monday and deletes policies that have not been used for any domain names. An empty WAF protection policy has only a policy name but does not have any domain name.
- Log in to the WAF console.
- Click
in the upper left corner and select a region or project. - (Optional) If you have enabled the enterprise project function, in the upper part of the navigation pane on the left, select your enterprise project from the Filter by enterprise project drop-down list. Then, WAF will display the related security data in the enterprise project on the page.
- In the navigation pane on the left, choose Policies to view the protection policy list. An empty WAF protection policy has only a policy name but does not have any domain name.
- After the WAF clear Non-domain Policy playbook takes effect, empty WAF protection policies will be deleted.
